Old 05-31-2006, 10:19 AM   #1
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
another A/C circuit to efan question
Ok, yes it's another "I'm using the AC circuit on an S14 to power my FALs" thread.
But the problem is, I want it to work just like the stock fan but have it power my FALs instead. I have a S15 SR20DET with no AC pump or triple pressure switch installed. I took them off. I used the connector for the stock fan (4 wires) two of which were black which I soldered to the black wire for the fans and the other two power (high and low) wires off the connector I connected to the power line of the fan.
When I crank over the motor, have the AC button pressed and fan switch on the console switched to 1-4, the FALS don't do shit....they should. Is this because I don't have the pump or triple pressure switch hooked up? I don't want to have to put that stuff back in just to get my fans working. Is there a way, if what I said above is stopping it from working, to bypass the triple pressure switch or somehow close the circuit to make the AC button work to turn on my fans...without AC??
Thanks guys
sean350z is offline   Reply With Quote
Old 05-31-2006, 02:19 PM   #2
sean350z
sean350z's Avatar
anyone??????
