Old 05-31-2006, 09:48 PM   #1
ESone3
ESone3's Avatar
ESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of light
What Do I Need For A Oil Pressure Guage
I have the typical oil leaking from the oil pressure switch so i'm going to add a oil pressure guage and replace the oil sensor. I hear you need a special fitting 1/8 BSPT to 1/8 NTP.... and i have no idea what that means or what i need to get. Any help would be greatly apprciated.
ESone3 is offline   Reply With Quote
Old 05-31-2006, 10:06 PM   #2
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
bspt means british standard pipe tapered and npt means national pipe thread, if my memory serves me correctly
about the pressure gauge, im guessing you would need to T it off your oil pressure sensor
undesiredshoe is offline   Reply With Quote
Old 06-01-2006, 06:23 AM   #3
cotbu
cotbu's Avatar
what engine? what kind of guage?(sending unit or fluid) usually this works
If you can see, the fitting is 1/8 which means you can probably use a 2nd sending unit.(1/8)
PART NUMBER
Old 06-01-2006, 07:22 AM   #4
projectRDM
projectRDM's Avatar
Don't T off anything. Remove and discard the OE pressure switch. A new OE switch will begin to leak in 6months anyway, and with a true gauge in the car you don't need it.
Plus it's nice to be able to see a problem before it occurs, with the OE switch you're mearly getting confirmation that you've already thrown a rod out the block.
Old 06-01-2006, 07:54 AM   #5
ESone3
ESone3's Avatar
yeah, i don't want to use the stock piece being that i've have a problem with my exisiting.
Can anyone direct me to a place I can get a fitting of some sort to fit directly with the sending unit for a VDO gauge?
I have a s13 redtop SR
Old 06-01-2006, 08:34 AM   #6
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
IIRC VDO uses 1/8" NPT
www.mcmaster.com
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 06-01-2006, 10:30 AM   #7
bgindn
bgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud of
Send a message via AIM to bgindn Send a message via Yahoo to bgindn
Marshall Instruments:
http://www.marshallinstruments.com/c...erformance.cfm
bgindn is offline   Reply With Quote
Old 06-01-2006, 01:56 PM   #8
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
dude theres a quite a few threads on this. u can also get the adapter to nps at splparts.com
ta ta
hydropgrahics!
ls1......
Old 06-01-2006, 07:00 PM   #9
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
or you can just get pimp ass DEFI gauges and the sensor fits in without a fitting...booya
sean350z is offline   Reply With Quote
Old 06-02-2006, 02:13 PM   #10
420sx
420sx's Avatar
same goes for any jdm gauges.
hydropgrahics!
ls1......
Old 06-02-2006, 05:44 PM   #11
hipro
hipro is an unknown quantity at this point
I have some good quality adapters for $20 shipped. Made of heavy, cadmium plated steel, with fittings for both 1/8 BSPT AND 1/8 NTP threads. Picture below. Thanks, Mike Browning www.hiprollc.com
hipro is offline   Reply With Quote
