Old 06-03-2006, 01:43 PM   #1
Sliding Ninja
Sliding Ninja's Avatar
Sliding Ninja has a little shameless behavior in the past
KA how do reset the ecu?
how do u reset the ecu?
Sliding Ninja is offline   Reply With Quote
Old 06-03-2006, 01:49 PM   #2
boroboros14
boroboros14's Avatar
boroboros14 is an unknown quantity at this point
unplug the negative battery terminal, let it sit for about 15 minutes, then put it back on.
boroboros14 is offline   Reply With Quote
Old 06-03-2006, 03:05 PM   #3
P4rD0nM3
P4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of light
OR, go to your ecu and put it in mode iv. Just remember though, even if you keep resetting the ecu, if you still have that problem, it'll jsut come back. Might as well fix it...
P4rD0nM3 is offline   Reply With Quote
Old 06-03-2006, 03:18 PM   #4
boroboros14
yeah and if you do decide to unplug the negative terminal be careful not to get shocked.
Old 06-04-2006, 09:51 AM   #5
Sliding Ninja
i didn't know you were that clumsy to get shocked?
Old 06-04-2006, 09:48 PM   #6
!Zar!
!Zar!'s Avatar
Why would he get shocked?
There is no need to unplug the battery.
But if you were to do this method, you unplug the positive and negative then touch them together for a few minutes. Then after that the code might be cleared.
But the propper method is to go to your ecu and pull the codes.
Old 06-03-2006, 05:29 PM   #7
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
http://www.ka24development.com/ecu_codes.html
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 06-04-2006, 01:02 AM   #8
g6civcx
g6civcx's Avatar
Remember to let the car idle for about 10 minutes afterwards.
Old 01-26-2019, 10:36 PM   #9
kichigai1
kichigai1 is an unknown quantity at this point
I searched and found several instruction on how to reset or clear the trouble code. None of them work after several tries.
I did more research and found this which eventually worked for me:
After you read the code, you can start the engine
Turn the bolt back to the clockwise position for at least 2 seconds(While running)
Turn it back to the counterclockwise position
Now shut the car and then start it again, this should of removed the code."
kichigai1 is offline   Reply With Quote
