Old 07-06-2006, 10:38 AM   #1
blktop-sr20
blktop-sr20 is a well-known jackass
sr20det help!
i need to know whats the replacement clutch on a sr am not looking to spend alot money all i know is that you could use one off a nissan maxima well can some one tell me the year and whats the better brand to use thanks.
blktop-sr20 is offline   Reply With Quote
Old 07-06-2006, 12:46 PM   #2
FlyingChicken
FlyingChicken is an unknown quantity at this point
Send a message via AIM to FlyingChicken
you could probably find something under 200 bucks on ebay for the sr20det
FlyingChicken is offline   Reply With Quote
Old 07-06-2006, 12:46 PM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
There are many posts about inexpensive clutches. Spend the right amount of money now, not more later.
Slidin240Wayz is offline   Reply With Quote
Old 07-06-2006, 01:56 PM   #4
blktop-sr20
what clutch would you guys recomend me to buy?
Old 07-06-2006, 02:46 PM   #5
kandyflip445
kandyflip445's Avatar
Look around at sr shops online. If you are just running stock boost and are going to keep it that way for a while, like over 10k miles or more, then I would suggest the lowest line of clutch you can get that suits your budget. Make sure you follow the proper break in procedure for you clutch or it will not last. That goes for any clutch you buy.
My 240 vBgarage
Old 07-06-2006, 03:20 PM   #6
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
you can get a oem replacement from exedy... under 130 for everything
IAM_SO_sLOw is offline   Reply With Quote
