Old 07-26-2006, 11:37 AM   #1
white smoke
white smoke's Avatar
white smoke is a well-known jackass
s13 Silvia Headlights ~~Halogen/Dual/Triple~~
I am doing a Silvia conversion on my s13 and I am wondering what are some advantages/disadvantages of each of these lighting setups?
I also have some general questions about the lights as well....
1) It seems that the halogens/bricks are the hot stuff right now but my question is why? Purely looks?
2) If I do an HID conversion on the dual or triple projectors, whats the cutoff like? (mention the brands of HID kits if possible)
3) All three sets of headlights have fog lights built in, how are people wiring them up to the pop-up switch? A how-to link or schematic would be awesome! Seems like it would be a simple relay circuit.
4) How does the projector fog light (triples) compare to the standard fog light (duals) as far as output goes?
Thanks Guys/Gals
white smoke is offline   Reply With Quote
Old 07-26-2006, 02:29 PM   #2
g6civcx
g6civcx's Avatar
1) Yes. There is no other benefit to the double.
2) Search on other forums. Zilvia is too jumbled to find this info.
3) Search this forum for "fog". See my multiple threads with multiple pictures.
4) Much better in my opinion.
Other benefits to the triple in my opinion:
a) Separate high and low beam bulbs for more reliability.
b) More adjustment to beam pattern.
c) More popular = easier to find spares in case of accident.
d) Cheaper.
Convert all H3C bulbs to H3 and you're good to go. Also don't forget to adjust them to US beam pattern.
Old 07-30-2006, 01:02 PM   #3
white smoke
Well I have found most of the info I need, thank sg6civcx.
My main concern was the cutoff and I have found out that the cutoff is fine but is setup for RHD (obviously) so they cant be used properly without either changing/modifying the shield or swapping the projector.
Im now really interested in comments about #4:
Thanks
Old 07-30-2006, 01:23 PM   #4
ThatGuy
Admin Asshole
ThatGuy's Avatar
Dual Reflector Headlights do not have foglights. Only the projector headlights have foglights built in.
Old 07-31-2006, 09:30 AM   #5
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
not true from what ive read.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 07-31-2006, 09:49 AM   #6
Yuri
Ghost of Zilvia past
Yuri's Avatar
No, what thatGuy said is right. the Dual Halogens do not have fogs. The inner lights that everyone thinks are fogs are auxilary high-beams meant to come on with the main highbeams. Hence people thinking that they are superior to projector foglights, when in reality your just blinding everyone.
The Halogens have much better lighting than the projectors (from experiance), and they use H4's which are much easier to find than the bulbs for the projectors.
Yuri is offline   Reply With Quote
Old 07-31-2006, 12:17 PM   #7
g6civcx
g6civcx's Avatar
From the FAQ.
Halogens:
Foglamps - H3c
Hi/Lo - H4
Dual Projectors:
Lowbeams - H3c
Highbeams - H3
Foglamps - H3c
Triple Projectors:
Lowbeams - H1
Highbeams - H3
Foglamps - H3c
Old 07-31-2006, 12:22 PM   #8
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
the bricks are also popular now because...guessing back then everyone wanted the projectors...now everyone got em the bricks are the new hot fad.
TipStylez is offline   Reply With Quote
Old 07-31-2006, 12:25 PM   #9
g6civcx
g6civcx's Avatar
I like the 97-98 US front end.
Old 07-31-2006, 12:25 PM   #10
LA_phantom_240
Cool, i stand corrected. Thanks for the good info
Old 07-31-2006, 08:53 PM   #11
SlowCoupe
SlowCoupe's Avatar
SlowCoupe is an unknown quantity at this point
Send a message via AIM to SlowCoupe
true that! i am currently using the dual halogen headlights until i do my lexus projector retrofit in my dual projector headlights.
cut off on the dual projector headlights is decent. but remember its for RHD so it flares to the left, which blinds on comming traffic if used LHD cars. and also projectors with the HID kit does not put alot of light on the ground. IT SUCKS.
SlowCoupe is offline   Reply With Quote
Old 08-02-2006, 11:09 PM   #12
S14DB
AFC #1
S14DB's Avatar
Bricks are much cheaper than the Projectors
Old 08-03-2006, 10:21 AM   #13
Yuri
Yuri's Avatar
S14 Kouki headlights>upgraded flip-ups>S13 Silvia headlights... in terms of light output.
Old 08-03-2006, 10:32 AM   #14
S14DB
AFC #1
S14DB's Avatar
Porsche Xeon retrofit into Projectors FTW.
