Old 06-24-2002, 12:43 PM   #1
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
Ok well right now i am in the mist of completely redueing my webpage and I need help on some html codeing.I am trying to work with frames and i am trying to figure out a few things.
1.How to link a whole folder so when it is clicked it will open and list the carsor what ever the link is relivent to.I want it to do this bare with me.
example.
Car picture's"click here when on a web-page not now"
then it will open and look like this.
Car picture's
etc.....
Then when they click that and the menu come out they can click the image they want and then it shows up in the rightside /middle of the page instead of openinga new window.
BEISSEN is offline   Reply With Quote
Old 06-24-2002, 12:52 PM   #2
DrDubbleB
DrDubbleB is an unknown quantity at this point
I don't quite understand what you mean.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Car picture's"click here when on a web-page not now"
Car picture's
car3.jpg</td></tr></table><span id='postcolor'>
If you mean that basically the "Car Picture's" is going to be a menu, and then opens up a sub menu that includes pictures (and maybe rollovers?) it's doable, but it's not going to be in HTML.
If you meant something else, please let me know and try to clarify.
DrDubbleB is offline   Reply With Quote
Old 06-24-2002, 01:04 PM   #3
kerv
kerv is an unknown quantity at this point
If you want them to open in a new window, you have to put a target string in your link.
For example,
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Code Sample </td></tr><tr><td id="CODE"><a href="http://kerv.net/images/car/" target="newcarwindow">My Car Pictures</a></td></tr></table><span id='postcolor'>
It will look like this
Does this answer your question?
- Kev
Kerv
89 Nissan 240sx FB
Alberta Canada
kerv is offline   Reply With Quote
Old 06-24-2002, 02:18 PM   #4
SimpleS14
SimpleS14's Avatar
I kinda get what you mean....
When you click on "Car pictures" alittle menu will show up under "Car picture", then when you click on any of those options the picture will show up on the right hand side.
There are two things you can do, HTML or use a Java script. &nbsp;Here is an example of the Java menu on the my webpage that I'm working on:
My Webpage
Click on "Info about my car", then "Pictures". &nbsp;maybe that can be a good example of what you want.
If you like it or want more info on the HTML way, just PM because its alot of coding.
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 06-24-2002, 02:47 PM   #5
DrDubbleB
The only way I can think of using HTML is using DHTML, which basically is Javascript along with a more powerful HTML language...could be wrong though.
Old 06-24-2002, 02:56 PM   #6
BEISSEN
Ok hey gtspecr i like what you have.Where you have info on my car that menu that comes underneth it can you help me on how to do that i like that cus i will have several menus in the following catagories.But i can acctully put them in or under one name and have a fall down menu like yours that says images or something to that nature.
1.carmeet pictures
2.engine picture's
3.audio picture's
4.member picture's
5.car picture's
Performance Area
1.Dyno Sheets
2.Performance Parts
Installs, Conversions
and steps.
1.Custome installs
2.Coversion pictures and steps
Wheels and tires
body styleing.
Old 06-24-2002, 05:04 PM   #7
SimpleS14
SimpleS14's Avatar
What I used is basically what DrDubbleB has mentioned...DHTML. The source code was not my own creation, it was sourced from someone else. Here is link to the exact page, where you can find the source code and learn how to use it and change it around.
Source codes
DEMO
Once you check it out, you can see how it works and how it can help you out with what you need. If you have anymore questions about the script or using frames feel free to ask.
L.H.O.O.Q.
Old 06-24-2002, 07:53 PM   #8
BEISSEN
Ok well i dont understand any of that stuff in there so if you can send me you text in a e-mail or pm it would be hekpful but for right now i have everything going to the right side if you guys want to see what i have done then click my link.
My New Web-Page
Old 06-24-2002, 08:24 PM   #9
SimpleS14
SimpleS14's Avatar
What part of VA do you live in? &nbsp;I live in Woodbridge.
As for the codes I can sent it to you, but I know you'll be even more confused.
I will give you the code with comments trying to explain what everything (almost everything) means. &nbsp;My a new page for the menu, copy and paste the code and play around with it offline.
L.H.O.O.Q.
Old 06-24-2002, 08:46 PM   #10
Zemus
Zemus's Avatar
Zemus is an unknown quantity at this point
Send a message via AIM to Zemus
if you need help with a layout i could help you out, http://www.fusion-tv.com/~ic
thats it so far, you can message me at Zemus on AIM
Zemus is offline   Reply With Quote
Old 06-24-2002, 08:46 PM   #11
Annoying Eric
Annoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura about
Send a message via AIM to Annoying Eric
go to htmlgoodies.com, its really good when i need help.....
Annoying Eric is offline   Reply With Quote
Old 06-24-2002, 08:48 PM   #12
SimpleS14
SimpleS14's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Oni @ June 23 2002,10:46)</td></tr><tr><td id="QUOTE">if you need help with a layout i could help you out, http://www.fusion-tv.com/~ic
thats it so far, you can message me at Zemus on AIM</td></tr></table><span id='postcolor'>
That is a good layout, where did you find those pics?
L.H.O.O.Q.
