Old 08-27-2006, 08:54 PM   #1
staygold24
staygold24's Avatar
staygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enough
Tranny Whine In Fifth
For the last few days Ive been having problem with a whining noise from the tranny. It only occurs in fifth so I dont think it could be from the pilot bearing could it? Also it is only during fifth and is very faint. I have not flushed the fluids in a while but why would it only come during fifth. It also increases in sound as the rpms go up. I did search but maybe for the wrong thing.
Thanks
staygold24 is offline   Reply With Quote
Old 09-07-2006, 05:20 PM   #2
staygold24
staygold24's Avatar
Is now whining in all gears except when clutch is engaged. Throwout bearing?
Old 09-08-2006, 10:52 AM   #3
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
When idling in neutral and the clutch engaged is there a whining sound? If so, more than likely your throw out bearing.
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 09-08-2006, 12:29 PM   #4
aznpoopy
aznpoopy's Avatar
clutch pedal down / clutch disengaged = throw out bearing
whine while driving / idling in neutral with cluch pedal up = stuff inside transmission
aznpoopy is offline   Reply With Quote
Old 09-08-2006, 10:48 AM   #5
gearhead290
gearhead290 is an unknown quantity at this point
Send a message via AIM to gearhead290 Send a message via MSN to gearhead290
it whines when the clutch is engaged or disengaged (clutch pressed in)? Sounds like a bearing or bearings in the tranny. Check your fluid, I bet it's low.
gearhead290 is offline   Reply With Quote
Old 09-08-2006, 01:02 PM   #6
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
Mine whines in reverse sometimes.
SnakeKack is offline   Reply With Quote
Old 09-08-2006, 01:05 PM   #7
aznpoopy
aznpoopy's Avatar
unelss its a loud scary whine, that's normal
just about every car i've driven makes a whine going in reverse
Old 09-08-2006, 01:11 PM   #8
SnakeKack
Yeah I notice alot of FWD cars do it. My old S13 never did it but it doesn't bother me since I hear it from other cars all the time.
Old 09-08-2006, 01:45 PM   #9
staygold24
staygold24's Avatar
im gonna go test it out to see when it does it. Could it just be from bad or low fluid? I havent changed it in a while. Im picking it up today cause I got a flat tire. Ill update later
Old 09-08-2006, 01:59 PM   #10
aznpoopy
aznpoopy's Avatar
yes it could be
with the car cold open up the tranny fill plug
stick finger in
fluid level should be right under the plug hole
Old 09-08-2006, 11:35 PM   #11
staygold24
staygold24's Avatar
allright im gonna change the fluid and see if that does it for the fifth gear whine which I still have. I realized the tranny whine wasnt a tranny whine but coming from the turbo when I spool up.
I searched and it said a gasket maybe? Or could my seals be going out? The turbo doesnt have any shaft play and also just has a fine mist of oil in the intake. No puddles of any kind. Still pulls hard as well.
Old 09-10-2006, 02:52 PM   #12
24Dee
24Dee is making a name for him/her self24Dee is making a name for him/her self
I've got tranny whine in ALL gears now... has gotten progessively worse since my last oil change about 3k miles ago... at that time i ALSO flushed my tranny and used Redline fluid instead of the regular fluid that was originally in there...
no grinding or slippage that i'm aware of and the t/o bearing was brand new when i did my 5spd swap in october.
24Dee is offline   Reply With Quote
