Old 09-10-2006, 02:29 AM   #1
serah31500
Trader Rating: (18)
serah31500 is an unknown quantity at this point
Feedback Score: 18 reviews
Car wont start
Okay I have just completed my swap.I have a 95 s14 with s14vtc swap.The car was an original 5speed and the harness was done by Yury at Wiring Specialties.The only action I get when I turn the key is the airbag light and the factory security light.I have searched around and pretty much tried almost everything including checking the grounds,fuses,wiring,etc with no luck.I am pretty sure it will turn out to be something stupid.If anyone can provide some helpful suggestions lmk as I am almost ready to bust out the gas can and matches.Thanks for your time guys.
serah31500 is offline   Reply With Quote
Old 09-10-2006, 09:11 AM   #2
MugeNismo
MugeNismo is an unknown quantity at this point
will it crank over at all? if not check the starter, altenator, and such. if it does listen for the fuel pump to prime the lines when you turn the ignition on also check for spark. thats what i would do but im no expert, hope it helps
MugeNismo is offline   Reply With Quote
Old 09-10-2006, 09:51 AM   #3
g6civcx
g6civcx's Avatar
Check all your fuses and fusible links in the underhood and underdash fuseboxes. Also check all your relays in the relay boxes.
I would check your starter wiring. Pull up the FSM and start tracing power flow. Something is preventing your starter from turning.
