Old 09-10-2006, 06:27 PM   #1
94plum
94plum's Avatar
94plum is on the path to ruin94plum is on the path to ruin
s13 Removing fenders??
I bought a new fender and i was planning on taking off my stock one before the new fender came in but there is one screw located on the inside of the fender when the door is opened...my problem is i cannot reach the screw b/c the fender is dented...is there any other ways i can take the screw out??
I tried a screw driver, wrench and drill
What else can i try
94plum is offline   Reply With Quote
Old 09-10-2006, 06:28 PM   #2
LB.Motoring
LB.Motoring's Avatar
Pry that b*tch back hahaha
Robby Leuer
Old 09-11-2006, 12:28 AM   #3
frank98dsm
frank98dsm's Avatar
frank98dsm is an unknown quantity at this point
dont mess up that little bracket if you can cut the fender
frank98dsm is offline   Reply With Quote
Old 09-11-2006, 01:01 AM   #4
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Your answer's simple. Take the tire off & remove the screws holding the plastic fender liner in place. Once the screws are out, remove the plastic fender liner. Removing the plastic fender liner will give you access to the inside part of the fender. Use a pry bar to push the damaged fender portion out of the way & then use a Bolt-Out screw extractor kit to remove your stuck screw.
Hope this helps...
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
