t25 to t28 swap ????
i have a redtop sr20, i blew my T25, so i'm now upgrading to T28 on a budget, only have 1,100 to spend... what do i absoulutly needs for the s15 t28 swap?
i plan on getting an aftermarket elbow, and piping adapter kit. but are oil lines needed? or can i use the stock hardlines? someone please help! |
i believe you need an oil restricter (sp) as well. because the t25 is journal bearing and t28 bb or it will ruin the seals. I dont really know though. Also s15 t28 will max out injectors so new ones will be need unless run really low boost and if you get injectors you will need safc or new rom tune.
![]() Join Date: Jun 2004
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
eh, dont worry about your injectors and such, just run stock boost you'll be fine. while you're changing everythign out you might as well change to ss turbo lines (get banjo style oil line). dont really need a new oil return tube; just notch the flange so it fits on the s15 turbo and you're good to go. that should keep you under your budget.
#4 | |
#7 |
![]() Join Date: Apr 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
10psi on the t28 is pushing it with stock injectors. I just installed my t28 on my redtop. There are a few ways of doing it.
MAKE SURE you get a s15 oil return line/hose. It makes things so much easier. I used an aftermarket oil line, aftermarket coolant line, and stock coolant hard line from the t25. The hard line im talking about is the one going to the back of the engine. It will need to be bent a bit inward to connect, be careful when you do this. Putting in the turbo is a BITCH. Its a very tight fit.
#8 |
hey 1,100 ill sale u my whole setup..... s15 turbo... magan exh mani.,adjustable wga, silk road outlet, intake outlet, baker(same ass taka) braided steel lines(new), i have it set @ 12 never used over that, nismo 555cc injectors, everything is used for about 4-5 months .....(except the lines) and will also add the hot pipe ... basicly u buy once u recieve its plug and play ..... well u will maybe need a safc.... but if u send me ur stock injectors ... i will also sale u my safc 2 add $125 just cause it would be a package ... so yeah everything for 1225 + shipping or just the turbo setup for 900 shipped lmk ....
"WhEn SoMeOnE yOu DoNt KnOw HaTeS yOu ThAtS wHeN yOu KnOw YoUr ThE bEsT" ![]() |
