hey guys...ran into another problem. WHen installng my cams I didnt mark the OEM camgear sprokets, or chain. ANyways I took the cams out, head off, put in new headstuds/gasket. Then put the head back on. Now...this is where im stuck. I have the sprokets bolted to the cams...layed both intake and exhuast in their spots. I turned the crank over until the crank pully is reading TDC (OR SO I THINK? please check pic #2) With this being "TDC" I can now line up my camspokets to the chain. (OR SO I THINK? Please check pic #1) I tried reading the factory FSM but am not sure. Pics #1 shows the cam sproket holes lining up with what I think are the "2 silver chain marks". Also when I took off the Chain tensoner and tried turning it over by hand it skipped a little teeth(skipping on the cam sproket or from the bottom I do not know. PLease look at the pics and If you can see if its wrong let me know how to fix it. Sorry for the rant,...and thanks for all the info you guys have helped me alot!
pic#1
pic#2
