Old 11-21-2006, 04:41 PM   #1
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
Speed Sensor
so...I just hooked up the s13 speed sensor on my tranny to my s14 car. Went for a drive and the MPH is ridiculous. When I'm driving like 45mph it says that I'm going 120mph or higher! What is the difference between the s14 and s13 VSS? My understanding is that they simply work off the principle of magnetic induction; it's just a coil, right? I just want to KNOW precisely why it doesn't work. thanks
shayrgob240 is offline   Reply With Quote
Old 11-21-2006, 04:43 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
You can't use an s13 sensor on an s14 tranny. The pinion gear is different.
Old 11-21-2006, 04:45 PM   #3
shayrgob240
maybe I got the polarity reveresed? I hooked up the green to red and black to red/yellow. I"m thinking about switching them around and seeing what happens
Old 11-21-2006, 04:47 PM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
No, you didn't reverse the polarity. the gearing is different between the 2 sensors.
Originally Posted by R240NA
To clarify, you can use either VSS since the transmission is the same. However, the S13 VSS won't read properly with an S14 cluster.
Old 11-21-2006, 05:08 PM   #5
shayrgob240
so all I really need is an s14 pinion? I wish I could buy that seperately.
Old 11-21-2006, 05:42 PM   #6
S14DB
AFC #1
S14DB's Avatar
You need a S14 VSS. They have different pulse widths,
Old 11-21-2006, 06:23 PM   #7
projectRDM
projectRDM's Avatar
Motherfuck.
Use the VSS that matches the cluster. Nothing else matters. I know I've typed that a dozen times this year alone.
