A/C and intake question
I was thinking about 'testing' this idea and seeing if it would work, but just thought I would ask before I went down this path. I searched the forum and didnt see any one else post this idea.
When you turn on your A/C unit it takes somewhere between 10-15HP from the motor to turn the compressor. This is a reason why a lot of people just pull their A/C units out, it lightens the vehicle and dont have to worry about that power loss. What I want to do is run a line from the Evaporator Low Pressure/Low Temp Vapor line into my Intake. My plan is to counter act the HP loss (and hopefully see some gain) while continuing to stay cool in my vehicle. It wouldnt require much work and may just be worth it. Any thoughts or opinions on this? Also, I'm open to be hazed since this is my first post. |
![]() Join Date: Dec 2002
The compressor does not pull that much power, it's *maybe* 5HP.
The A/C system is sealed for a reason, introducing the intake charge into it would blow all kinds of shit from the crankcase breather, carbon canister, fuel vapor purge line, and PCV into the A/C and trash the compressor, condensor, and evaporator, not to mention you'd intake a good amount of oil from the compressor and burn it in the engine. Plus, unless you plumbed it in before the MAF, you'd be doing nothing but leaning out the engine heavily as there'd be a large amount of unmetered air entering the engine. In other words, that's one of the dumbest fucking ideas yet. |
#5 |
How would you blow anything? Do you even know how A/C systems work? The only thing that would happen from adding another line from your low side low vapor evaporator would do is add more area, which in turn would add lower pressure. The whole oil thing is a complete falacy, since if you have oil in your system by the time it is leaving the evaporator and going back to the compressor your system is already fucked anyways. And unmonitored air flow? All I'm talking about is cooling the air that is already being pulled in with your refrigeration system. Kinda similar to spraying your intercooler. Your the fuckin reason why so many sites have bad information. You dont fully know how things work and pretend you do. Do some research on refrigeration systems before you start posting stupid fucking answers. Also, the average pull for an A/C compressor is about 10hp, at least on high, although 5hp is more reasonable, so I'll give you that. Do your fuckin research! I dont have a problem if its a dumb idea but I have a problem with ignorant dicks that dont know what they're talking about, at least in this instance. You might be knowledgable in some areas R240NA but obviously not this one.
#6 | |
Secondly, your question stated that you wanted to use intake air to lower the pressure. By doing so, you're introducing whatever is in the intake into the A/C low pressure side. Again, PCV blowby, crankcase blowby, fuel vapors vented from the tank, all this is ported into the intake on a normal car. Unless you've removed all of that you're not filtering that air at all. Doing so after the mass airflow sensor would change the overall metering, since some of it would be displaced by channeling it elsewhere. Lastly, piping anything into the engine means it's burned in the engine, so the R134a you'd be using would be mixed into the airstream and combusted with the fuel, and though I don't know if R134a is even flammable, I know the resulting byproduct coming out the exhaust would not be clean at all. If that's not what you meant, learn how to form clearer thoughts and type them out so other people can know what's in your feeble little brain. Seems like your problem is that you're wanting to hear the answer you've already concluded to yourself, so why look for that answer knowing that you're just going to cry about it when you don't hear it? |
#7 |
Ok, neither of you know what you're talking about. First of all, there is a refridgerant that runs through the air pump. It condenses the R12, giving off heat. The R12 runs through the condenser, cooling it. It then runs through the AC box, which expands it, absorbing heat, then runs it through the heat exchanger. Air blows through the heat exchanger, cooling the air and heating the R12, and then runs back to the air pump.
What exactly do you want to do by running it through the intake? All that would do is spill R12 into the atmosphere and kill your lungs and your engine.
#8 | |||
#9 |
![]() Join Date: Jan 2004
Dont compressors clutches generally disengage at full throttle to allow that hp loss to not exist?....
To do this right the line would either have to coil around the intake tube covering a large surface area or be inside of the intake. Placing this chilled line inside of the intake would be the most efficent way for heat transfer but you would be restricting the flow. What you are suggesting sounds like a shit load of work for practically no power increase. Not only that, but you are doing a poor job communicating your thought and are getting mad when people are saying it is a stupid idea. Remember when you are speaking people dont know the idea you have. This has been thought of before.
I'm from Florida so I'm probably a bit more strange than you |
