![]() Join Date: Oct 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 35 reviews
Survey about Kaaz LSD
What fluid do you use for your Kaaz lsd.
Im just tryin g to decide which one I want to use on my 2way. I read that your are not supposed to use in organic gear oil for kaaz, but i was told that you can use te cusco synthetic. thanks. |
#6 |
Visit www.kaaz.com. They clearly state that synthetic is NOT RECOMMENDED for their differentials. The performance will be greatly diminished. The diff was designed for natural oil. If you don't want to use the kaaz brand oil, just use cheapo valvoline with ford friction modifier. That's what I'm using right now, and I think it works just fine. Plus, you can get all of that at autozone for about 10 bucks, instead of 50 for the kaaz stuff.
#7 | |
LAID OUT
![]() Join Date: Mar 2004
![]() ![]() ![]() Quote:
The clunk noise is by design; when you take a slow speed turn the clutch plates create friction against each other and against the springs. Eventually it is enough friction to allow them to slip slightly, before the spring locks them again. If you aren't using any friction modifier in your diff oil, your clutch pack lsd is supposed to clunk like that. If it's not making the noise anymore, it's possible the plates have been coated with something that is reducing their friction against each other, meaning the diff isn't locking as strong or as soon as it did when new. I've had my Kaaz a year now with 10k miles or so on it on genuine Kaaz fluid, it still clunks as loudly and as often as when it was brand new.... I use the genuine Kaaz oil without additives. There are some oil additives you can use to reduce the noise, but this works by reducing the friction between the plates, which sounds a little counter productive to me. Like running a 1" exhaust with cat, resonator and mufflers to reduce exhaust noise -- it'll work but at what expense? I'm sure lots of dudes run the friction modifiers with no noticeable effect, anyone have input/opinions on the friction modifiers? Last edited by MELLO*SOS; 12-05-2006 at 01:24 PM.. |
#9 |
YOU MUST US KAAZ OIL...
it will void any chance of kaaz fixing it or refunding your $$ ... When I read instructions...it scared me so many warnings and what not... Good Luck... I hope you know you need to containers too! you have to break in and change after 30 mins of driving in figure 8's... caution you may get dizzy and puke... ![]() |
#10 |
If you're anywhere near OC I suggest going to Kaaz USA and having them do the install and break-in. Took mine there last week and Ray was great, ready to give advice on anything you ask, and willing to show you the handfull of cars they have in their garage.
#11 |
LAID OUT
The install is pretty easy I did it by myself in my garage. Be careful lowering the pumpkin though, if it falls off the floor jack it could crush your hand or worse. If you buy from DriftFactory they'll get you a big can of oil, but like the other dude said you'll need another can for the post-break-in fluid change.
#12 | |
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
#14 |
![]() Join Date: Jun 2004
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
When did this turn into an install thread? I agree its worth the money to have Kaaz install it. But Robb already has his installed. I have used kaaz oil and had my diff for 2 years still works perfect, some cars are just noisier than others but the diff will always make noise. Just wait to change it till you have more money and can afford to change it. I went way too long a couple of times and the diff is fine. Your not at events twice a month so you can get by with going a little over your scheduled maintence. (so no one flames me I dont recommend people not changing their oil every 5,000miles but this is a different circumstance)
#15 |
thank you brian, I kow what you mean, I was just lookign at my options and I figured a survey would be a good way to be lazy and get input from others.
#16 |
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Vavoline 80w-90 with Ford frictin modifier all NON-synthetic. There was a representive from KAAZ on Drifting.com where he said you can use these instead of KAAZ fluid. Ive had my LSD since Dec. 05 and havent had a problem at all, just the clunk-clunk of it.
Slide Happy |
