Old 12-11-2006, 05:52 PM   #1
karazycrakr
karazycrakr is an unknown quantity at this point
valve spring levelers???
okay i lost one on the last valve spring on the exhaust side and it fell in the oil drain in the back of the motor. Anyone know if it would go all the way down to the pan or if it would hurt to leave it there and anyone know where to find that part i cant find it??
karazycrakr is offline   Reply With Quote
Old 12-11-2006, 07:24 PM   #2
Sileighty_85
Sileighty_85's Avatar
Are you talking about a Shim?
anything floating around in ur engine thats not suppose to be there is bad for your engine, it might end up clogging an oil passage or getting stuck in a spring and grenading ur valve train. Get one on those small magnets on a stick and start poking it in crevices in the head then drop the bottom oil pan
As for a replacement I'm not sure where to find one.
Old 12-11-2006, 08:44 PM   #3
smelly240
smelly240's Avatar
get a magnet on a stick tool (telescoping magnet for those of us that get raped by our friendly snap on man...) if all else fails pop the lower pan and poke around with the magnet that way... i cant tell you how many times my maggy saved my booty with those lil bastards.
i have dropped em more than once... i've even used that magnet to pull timing chains up when i accidentally drop em into the front cover
smelly240 is offline   Reply With Quote
Old 12-11-2006, 09:59 PM   #4
karazycrakr
yea i already poked around with a magnet and i found one of the shim's but the other little bastard got away so im gonna drop the oil pan tomorrow
