Old 12-29-2006, 04:09 PM   #1
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
SR blown headgasket?
so i have a s13 with a redtop sr20det. just a FMIC, FPR, and a MBC runing 10 PSI. on a stock sr. i was racing and came to a stop light and noticed that my idle turned into shit. so i pull over check crap out, pull my oil cap off and tons of air is shooting out of it. no oil in my coolent, and no water in my oil. blown headgasket?
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 12-29-2006, 04:12 PM   #2
TAMTANIUM
TAMTANIUM's Avatar
TAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the rough
niceee!! street racing and then blew the engine! Sweet life
TAMTANIUM is offline   Reply With Quote
Old 12-29-2006, 04:31 PM   #3
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
^^Pointless post.
That is what you call blow by, it can be caused by the top compression ring no longer sealing. A bad PCV valve, cause there should be vacuum in the crank case if the PCV valve is operation correctly. That is all I can think of for now.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 12-29-2006, 08:04 PM   #4
JDMClifford
flaming on my post when you could be helping. sweet life!
i was also think it was the rings because a friend of mine sr idles like my car does. and hes a blown ring. i checked out the pvc valve. dont se how it could stop working randomely, i maintain my car very well. i just went out and bought a piston ring set and rod barings for like 60 bucks. we will see how it goes when i pull the motor.
Originally Posted by ledzeppelin240
^^Pointless post.
Parking lot pimping
Old 12-29-2006, 08:17 PM   #5
johngriff
johngriff's Avatar
ok.
You are going to pull the engine?
Did you check the PCV? Alot of engines have blow by, some worse than others.
Did you do a compresion test?
Change the oil to a heavier weight to see what is going on, that might seal up the top ring. ***FOR NOW***
And, dont run 10psi w/o fuel correction, where will the extra fuel come from?
Where will the extra fuel come from?
Where?
[email protected]
Old 12-29-2006, 10:09 PM   #6
JDMClifford
im just going to pull the motor and rebuild it this week. i figure if its something simple it was still worth it because whoever swaped it didnt do a very good job. thare was a bunch of smog stuff and extra electrical plugs that dont need to be luying around. maby i will repaint the car with some high heat paint so it wont melt off agan.
Parking lot pimping
Old 12-29-2006, 10:41 PM   #7
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
dude you have gotta do a compression test before you pull an engine.
to check a pcv valve you should be able to blow through it in one direction and not in the other.
lazierhobo is offline   Reply With Quote
Old 12-30-2006, 02:35 AM   #8
JDMClifford
ok i will try to see if its the pvc valve. and i will try to do the compression. i really dont want to buy the tool. i will see if i can rent one.
Parking lot pimping
Old 12-31-2006, 02:10 AM   #9
ledzeppelin240
To correctly test the pcv valve, plug it off while the engine is running and the idle should drop slightly. Do a leakdown test rather than a compression test...
Old 12-31-2006, 03:40 AM   #10
johngriff
johngriff's Avatar
Leakdown requires more equipment, and can be done incorectly if you dont keep your eye on the PSI.
A compression tester is $13 at Kragen. BUY ONE.
[email protected]
Old 12-31-2006, 01:22 PM   #11
ledzeppelin240
All you need is gauge that can be made for about $10. So I don't know what you are talking about. A compression test will just tell you what cylinder has a problem. a leakdown test will pinpoint the problem even more.
Old 12-31-2006, 10:10 PM   #12
JDMClifford
well i tested the valde, works fine. i figured out why my idle was crap. i blew a hole in my cupler. so it only took 4 hours to pull the engine. now were im jsut gona wait till ym friend brings his air compressor over so we can take the flywheel off and will post more. maby pics on a diff thread showing how to rebuild the motor or something.
Parking lot pimping
Old 12-31-2006, 10:55 PM   #13
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
wtf? u still pulled the engine?
ladiesman8527 is offline   Reply With Quote
Old 12-31-2006, 11:11 PM   #14
JDMClifford
Ya. I need to rebuild it. pluss it takes less time to pull the motor than just drop the tanny without a lift. I could probably pull the motor in 2 hours if i wouldn't stop to smoke, get smokes, play videogames, go pee, get lunch. Stuff like that. Also it gives me an opportunity to remove all the unwanted brackets, tuck the whirring, repaint the engine bay, clean the engine, and clean up the holes from installing my fmic.
So i bought rings, rod barrings, and plastigage, and assembly lube. Anything i should buy? Got oil and stuff.
Parking lot pimping
Old 01-31-2007, 11:56 AM   #15
steve shadows
steve shadows's Avatar
So wait let me get this straight...
1. No compression test done
2. No idea if the motor is bad or not
3. You just pulled the Engine out of the car? for no reason?
ok...
well
You should have really done a dam compression test before you go ripping
stuff apart.
who knows whats wrong with it now, maybe you can put the tranny up to it and use a battery and and the starter on the bell housing to do a comp test with it out of the car- if that even makes remote sense to you.
sorry to hear you didnt diagnose first.
i would have just put my diagnosis on a bad thermostat...now your rebuilding your engine- have fun!
Like Me on FaceBook !
Old 01-01-2007, 12:13 AM   #16
S14DB
AFC #1
S14DB's Avatar
what you should have bought:
http://www.harborfreight.com/cpi/cta...emnumber=92697
Need to have your bores honed. Decks checked. Crank Journals checked for diameter and round. Check the Main bores and the Rod ends for diameter and round.
Kind of a waste to buy rings and bearings before you know what clearances you are dealing with.
Old 01-01-2007, 12:26 AM   #17
JDMClifford
ya my friend gona check all that he knows what he is doing. we just need to buy a hone. he has been trained to do all that crap.
Parking lot pimping
Old 01-01-2007, 12:59 AM   #18
S14DB
AFC #1
S14DB's Avatar
Buy a hone? Please tell me for your Sunnen and not your Makita.
Old 01-01-2007, 02:30 PM   #19
cmcdougle
cmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to behold
Send a message via MSN to cmcdougle
you can hone an engine yourself? How do you do it?
cmcdougle is offline   Reply With Quote
Old 01-01-2007, 02:37 PM   #20
yfz460
yfz460's Avatar
Trader Rating: (24)
yfz460 is making a name for him/her selfyfz460 is making a name for him/her self
Feedback Score: 24 reviews
Send a message via AIM to yfz460
They make honing tools for standard drills.... we use them on lawnmower engines in our school class. They work good for those things, but I wouldnt trust them on something so valuable and precise as an automotive engine. (Especially and engine that goes for more than some of the cars they're getting swaped into sell for!)
People build cars to please zilvia.
yfz460 is offline   Reply With Quote
Old 01-01-2007, 02:43 PM   #21
johngriff
johngriff's Avatar
Yeah, there is quite a bit of machine shop prep work that should be done by a machine shop.
[email protected]
Old 01-01-2007, 11:20 PM   #22
JDMClifford
why not for an automotive engine, drill press+hone= honed.... whats the big deal about that? i have red hundreds on builds whare people do it them self.
here is an example of a write up on how they work.
Any time you install new piston rings you need to hone the cylinder walls to break the glaze in order to allow the new rings to wear in and seat properly to minimize oil consumption. The hone has a flexible drive shaft and is typically driven with a 3/8" electric hand drill at speed under 1000 rpm. A pro shop might use a hone in a drill press to run it as straight as possible and to have better control over axial motion to produce a cross hatch pattern on the cylinder wall.
If the cylinder is fairly clean and not significantly scratched you could use a flex hone (often called a ball hone) to break the glaze and remove minimal material. These are quick and easy to use but need to have a fairly close match to the bore size. If it's smaller than the bore it won't work. If it's much larger than the bore it will be difficult to keep the balls inside the cylinder with close approach to the ends of the bore. If you have more than one bore size to work with you need multiple tools. If the cylinder wall is slightly scratched, and you need to remove a little more material to get it to clean up, then the flex hone is not the best tool. It can remove material more in the middle of the bore and less at the ends, therefore causing the bore to be less straight.
The articulated three stone hone is a more universal cylinder tool. This may have a much greater working range to work with small bore and large bore engines, so you only need one hone. It should also help to keep a more constant bore size (straighter cylinder) when removing a little more material to clean up a slightly scratched cylinder. An abrasive hone is subject to wear as it is used, so the abrasive may need to be replaced occasionally (maybe every 30 to 50 cylinders or so). The straight stones are cheaper to replace than buying a new flex hone. If you like to use various grit grades, the straight stones are also fairly easy to change, as opposed to buying multiple flex hones.
With any honing process some of the abrasive grit wears off of the tool at the same time that fine metal powder is bring removed from the cylinder bore. This stuff is VERY bad for an engine if it is left inside. So it is best to do this honing on a completely disassembled and bare engine block, and clean it thoroughly before assembly. It is possible to hone cylinders with an engine still in the car and partially assembled. If you do this, pay special attention to keeping the grit off of the camshaft and crankshaft as well as possible, and do your best to clean everything thoroughly before reassembly. It would also be a good idea to install a magnetic oil drain plug, and to drain and change the engine oil soon after initial run in.
These tools may cost $20 to $40, might be found at J.C.Whitney or discount tool supply stores or at any auto parts store. Being prone to a certain amount of wear, they may be less likely to be available through a tool lending program, but it doesn't hurt to ask.
Parking lot pimping
Old 01-01-2007, 11:29 PM   #23
S14DB
AFC #1
S14DB's Avatar
You hear about the build 6 months later? When I was shopping for a machine shop last year I spent a day at a shop watching him rebuild someone else's mistake. amazing how much abuse that SR took and still ran.
Old 01-01-2007, 11:44 PM   #24
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
so your rebuilding your engine because you blew your intercooler coupler??
sblack13 is offline   Reply With Quote
Old 01-31-2007, 12:09 AM   #25
JDMClifford
no because i can, wan to, if im gona abuse it on the track i want to know it can handle it, i dont know how many miles it has on the motor, want to make sure everything is not worn or loose, had some extra money and time, have all the tools, got a great deal on the parts, measured the pistons and the rods to see it we could make them fit into a f23 to make a honda/nissan motor, whitch they might with a little creativity, and to learn how to do it for when i build it up to hold a gt2871r.
Parking lot pimping
Old 01-31-2007, 01:01 PM   #26
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
boy...you're just throwing away money on the rebuild, and you're not even taking the right approach. well, good luck to you. all you really needed to do was a leakdown and change out the valvetrain components and cams for the 2871.
kensreliableb18b is offline   Reply With Quote
Old 01-31-2007, 02:40 PM   #27
projectRDM
projectRDM's Avatar
He did learn one thing though, he's building this one so he can run it at the track, not on the street.
What a fucking clown, rebuilding an engine "because I can". Do you also stick your penis into gay men because you can?
Old 01-31-2007, 12:23 PM   #28
Markovich
Markovich's Avatar
Markovich is an unknown quantity at this point
i guess some people never learn o well at least we tryed to tell him to do a comp test its out of our hands now. i just think its funny he asked us (zilvia) to help him but does listen to what we say hahaha
peace
7-mount sr20det evo3 16g in a 90 240sx coupe
yes its a nisclipse bitch
Markovich is offline   Reply With Quote
Old 03-03-2007, 02:56 AM   #29
bensaccord
bensaccord is a well-known jackass
peace
Actually he did read what you said, everyone here actually found this thread quite amusing. Some helpful people, some post whores, but mostly a bunch of dicks. He not only figured out what the problem was (post #12), but he got experience pulling his motor, rebuilding it, cleaned up his engine bay, painted it, and did a nice little wire tuck while he was at it. Removed a bunch of unnecessary crap, learned a lot about his own car, and had the satisfaction of knowing he didn't have to pay someone to do the work on his own car.
I'm sure if it was his daily driver or the feeling of working on his own car made his pussy ache he might have paid someone way too much money to tell him what he eventually figured out for free. But he didn't, because he is an enthusiast. He likes doing this stuff. It occupies his free time,makes him happy. Isn't that what being an automotive enthusiast and shade tree mechanic is all about????
bensaccord is offline   Reply With Quote
Old 01-31-2007, 12:33 PM   #30
jdmsoles
jdmsoles is an unknown quantity at this point
^^ dude thats extacly what i was thinking, also it so pointless to just pull the engine, when you dont know what the problem is compression test it first the test only take about 10- 20 mins or so ya know better to be safe then to go all out and do bunch of nonesense.. right.
jdmsoles is offline   Reply With Quote
