Old 01-06-2007, 04:20 PM   #1
kdillard21
kdillard21 is an unknown quantity at this point
Send a message via AIM to kdillard21
Noisy transmission on deceleration
I have searched on other sites and found many people with the same problem. Really no solutions. I dont know where else to look. My problem is that I did the 5-speed swap about a year ago without any problems. Put on a fidanza lightweight aluminum flywheel, spec 2+ clutch, driveshaft shop aluminum driveshaft, and I already had aluminum pulleys, also have a B&M shifter. It hasn't been all that bad until recently, but now its LOUD when i left off the gas to let the engine brake. push the clutch in, goes away. it can sit in neutral and I can here the same noise but much softer. i recently had the driveshaft off, but there is no alignement marks, and they dont instruct it to be "aligned" for balance. Everything seems tight, but its like a pack of wild bees is trying to jump out of the transmission.
kdillard21 is offline   Reply With Quote
Old 01-19-2007, 11:24 AM   #2
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
I have the same noise coming from my shifter area. Have a B&M and stock flywheel, clutch driveshaft.
I just kinda figured it's from the shifter hole, no dampening due to the new shifter, allows for the tranny noise to travel through the shift linkage.
mmmm...?
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 01-19-2007, 11:31 AM   #3
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
My T5 from my Z31 was doing the same thing the main shaft bearing in the tranny was shoot. Needed Rebuild
F3600 is offline   Reply With Quote
Old 01-19-2007, 11:39 AM   #4
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
throwout bearing?
kevtrinh is offline   Reply With Quote
Old 01-19-2007, 11:51 AM   #5
atoczek
atoczek is an unknown quantity at this point
Input shaft bearing. Common to 5 spds. How many miles on the tranny?
atoczek is offline   Reply With Quote
Old 01-19-2007, 12:12 PM   #6
Dream240
Dream240's Avatar
Well mine I just got from a guy for the swap. Have no idea how many miles are on it. But I do know that the guy that used it before me drove the shit out of it. So yeah it makes sense that it would be a bearing, since it gets louder with the RPMs. And especially louder when I grab ahold of the shifter. When it just sits there not so much, even in gear.
Wierd.
Old 01-19-2007, 01:02 PM   #7
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
eheheheh... i have the same problem.... the grinding noise you hear when you don't have your foot on the clutch is the throw-out bearing or release bearing... its making noise because its telling you that its almost time to replace it... if it gets really loud to where that's all you hear then its time to replace it...
the noise you hear while your driving is the B&M short shifter... there really isn't a solution to that other than taking it off and using a stock unit...
if you do not have the budget to replace it any of these... i'd say just blast the radio or just imagine that you have a sequential gearbox in your JGTC car....
swayray is offline   Reply With Quote
Old 01-19-2007, 01:40 PM   #8
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Pretty much it's a combination of things.
B&M shifter makes noise when there's a lot of vibration in the driveline.
SR's and KA's both have mad driveline vibration on deceleration. This is dampened out by a stock organic disc sprung clutch and the stock driveshaft bushing. Anything different creates vibration. If you combine this with stiff motor mounts, it becomes worse. 6 pucks are notorious for creating noise and are the major cause of the vibration.
Flybert is offline   Reply With Quote
Old 01-19-2007, 01:55 PM   #9
Dream240
Dream240's Avatar
Yeah makes sense. Since I've got Nismo mounts and the B&M, plus I removed the clutch dampener box, I've got alot more vibration.
Old 01-20-2007, 09:48 AM   #10
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
Definetly the main input shaft bearing. I'd replace it quick before it causes more problems.
-Jeff
Originally Posted by McRussellPants
LoLoLoL, you gotta replace the wire on your mig with a spool of hopes and dreams.
Originally Posted by Fidelity101
Its one of them cars that runs on hopes and dreams, and a little bit of boost. lol
spdfreek0o is offline   Reply With Quote
Old 01-20-2007, 06:41 PM   #11
motonagam
motonagam's Avatar
motonagam is an unknown quantity at this point
I had the same problem as well with my original 5spd swap transmission... bad input shaft bearing. The input shaft bearing was so worn out, that I found there was about 1/4 inch input shaft endplay when I pulled the transmission out! It was also causing my clutch to chatter at friction point, because of so much endplay.
motonagam is offline   Reply With Quote
Old 01-20-2007, 06:50 PM   #12
motonagam
motonagam's Avatar
Hey Ray... you have it backwards. If it makes noise without having your foot on the clutch, it's a bearing inside the transmission, and not the throwout/release bearing, since the release bearing is not contacting the pressure plate fingers and making the bearing spin (that's why there's about a 1/4 inch of freeplay in the clutch pedal at the top. When you start feeling resistance in the clutch pedal, that's when the release bearing contacts the pressure plate). If it makes noise when you have your foot on the clutch pedal and transmission in neutral, then it is the release bearing. If it only makes noise with your foot on the clutch pedal while you have the transmission in gear, then it is the pilot bearing.
Old 01-21-2007, 11:58 AM   #13
swayray
swayray's Avatar
hehehe...that's what i ment to say Mr. ASE certified... thanks masashi...
Old 01-21-2007, 08:20 PM   #14
Rod
Rod's Avatar
Rod will become famous soon enoughRod will become famous soon enoughRod will become famous soon enoughRod will become famous soon enough
Hey Guys,
Had the same problem and i was able to rectify... Replace the transmission mount and run Redline Gear Oil - 2parts MT-90 and 1 part Heavy Duty Shockproof. I'm running nismo's and I also placed some black gasket maker in-between the transmission and the short shifter plate. Beleive it or not, I have no vibration noises all the way to 7200rpm. Might work for you guys as well.
PM me if you need any additional info...
Rod
Rod is offline   Reply With Quote
