Old 01-19-2007, 01:29 AM   #1
longdy
longdy's Avatar
longdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud of
Send a message via AIM to longdy
ahhh my SR is starting up!!!!!....help
alright just like the title of this tread says my sr20det red top isnt really starting right now
i really dont know what it is... i have tried basically everything up to my knowleage....
1st. i check to see if the battery was dead and it turned out to be very good still
2nd. i checked all the fuses under in the driver side kick panel and it was fine too
still the car didnt start
3rd i checked the starter but it is working fine because the motor turns without a problem but it just wont start!!!....
4th. so i check to see if there is fuel coming into the motor and running through fuel rail at all and there was plenty of fuel there
and from here i thought it would be the fuel filter so i decided to change it alone with all the fuel lines that feed into the fuel rail
in the end with that done still was turning the motor with no luck of actually running.....
5th i checked all the ground wiring and it seems as if there was nothing wrong with it at all .... the wires were perfect with no cuts or anything.......
in the END THE MOTOR DOES NOT TURN ON!!!!!!....
its funny when i am driving on a smooth road the motor is running fine then when i hit a bumpy road on the FWY or something the motor starts to choke or something like that where the rpm at 3000 jumps back and fourth between 3000 and 2000 rpm. ... I REALLY DONT GET THIS AT ALLLLLLL PLEASE HELP
o yea the fuel pump works perfectly fine... checked that tooo...
help please
longdy is offline   Reply With Quote
Old 01-19-2007, 01:35 AM   #2
IngS14
IngS14's Avatar
IngS14 is making a name for him/her selfIngS14 is making a name for him/her self
Send a message via AIM to IngS14
a buddy of mine has a s13 sr20det coupe in LB area.you can IM him at D3 Crono 562,he knows alot about sr motor.
IngS14 is offline   Reply With Quote
Old 01-19-2007, 01:55 AM   #3
longdy
longdy's Avatar
hey bro is that one word like D3Crono562... just like that or whats up..lol
Old 01-19-2007, 01:36 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
MAFS wiring bad? that would definitely do it... i had a similar problem with one of the SRs I did, when I didn't use good connections to the Mafs, which bounced around in the engine bay. Definitely worth a check ~
Old 01-19-2007, 01:57 AM   #5
longdy
longdy's Avatar
i checked a i think its on really tight lol!!!.... the clip is still on the so there shouldnt be any reason why it should be moving around.... thanks for the help though!!!.....
Old 01-19-2007, 06:59 AM   #6
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
Did you check for spark. Ignitor maybe.
nassin31spr is offline   Reply With Quote
Old 01-19-2007, 08:11 AM   #7
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
ur foot could just be bouncing on the pedal when u hit the bumps. no joke. i dont know what your suspensions like, but in my car, on bumpy roads its hard to keep my feet steady on the pedals. as for the not running, check for spark. also, just so you know, your title says "ahhh my SR IS starting up!!!"
ladiesman8527 is offline   Reply With Quote
