Old 01-20-2007, 06:36 PM   #1
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
Coilover size in relation to regular struts
here is my question. I have 17x9's +35 in the front. They clear my struts with a 5 mm spacer. My concern is with coils, that the wheels will hit. Anyone have any insight?
240silvia is offline   Reply With Quote
Old 01-20-2007, 06:55 PM   #2
gotta240
my front apexi coilovers are TINY in diameter compared to stock springs..
Old 01-20-2007, 06:57 PM   #3
TheTimanator
TheTimanator's Avatar
depending on tire size, camber, how low you are, what coilovers you get...
17x9 +20 clears most peoples coilovers without excessive camber
Old 01-20-2007, 07:01 PM   #4
240silvia
240silvia's Avatar
well with the camber in the front, the whole assembly moves, right. Do you think with the spacer I'll clear? KSport coils...
Old 01-20-2007, 07:12 PM   #5
TheTimanator
hoepfully this will make sense when I explain this. IIRC with the strut/spring combo your only clearing the strut, you don't have to worry about the spring b/c of how long the strut is. Coilovers however, the rim has clear the spring itself, and although the spring is much smaller width wise there is still less clearence.
Old 01-20-2007, 07:16 PM   #6
TheTimanator
with a 5mm spacer? no. I doubt a 10mm would do it either but you might get lucky. I'd go with a bolt-on 15-20mm to be safe. What size tires do you have?
Most people barely clear 9" wide with +20 offset and by that I mean a few mm.
Old 01-20-2007, 07:16 PM   #7
DriftSpecial180
DriftSpecial180's Avatar
DriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura about
I had those same wheels a little while ago. The guy i got them from gave me 25mm spacers with them and i barely had any clearance
DriftSpecial180 is offline   Reply With Quote
Old 01-20-2007, 07:29 PM   #8
LB.Motoring
LB.Motoring's Avatar
if they are clearing barely on struts,
YOU HAVE A PROBLEM.
Robby Leuer
Old 01-20-2007, 07:53 PM   #9
TheTimanator
haha, that's awesome!
basically what I was trying to explain but with a visual!
Old 01-21-2007, 02:12 AM   #10
240silvia
240silvia's Avatar
I've seen a white hatch on here before. Same wheels as me just a different color. It was SLAMMED on the wheels, had to be coils. I can't really use a bigger spacer. The wheels already stick out a lot. Anyone else have any ideas.
Old 01-21-2007, 02:31 AM   #11
yokotas13
yokotas13's Avatar
you can do it. if not, throwa ndother spacer ont aht bich
yokotas13 is offline   Reply With Quote
Old 01-21-2007, 02:32 AM   #12
240silvia
240silvia's Avatar
Grant, get on AIM!!!!!! See the wheel is already about 2-3mm outside of the front fender. I just don't want to have to do that! Then i'll have to get some damn wide fenders.
Old 01-21-2007, 02:37 AM   #13
yokotas13
yokotas13's Avatar
fine
slutgrsdagdrs
Old 01-21-2007, 11:25 AM   #14
DriftSpecial180
Dis one?
Old 01-21-2007, 11:31 AM   #15
240silvia
240silvia's Avatar
YES YES YES YES YES!!!! You are the man!!!! Any idea on who that is??? I know those are stock fenders because the extra bracket for the DOHC bumper has been taken off.
Old 01-22-2007, 12:21 AM   #16
DriftSpecial180
Thats my car fool. KTS coilovers with 25mm spacers.
You should see it now though, 10x better
Old 01-22-2007, 12:53 AM   #17
~4N~
~4N~'s Avatar
~4N~ is making a name for him/her self~4N~ is making a name for him/her self
Send a message via AIM to ~4N~
Anything that doesn't rub with shocks will fit with coilovers.
~4N~ is offline   Reply With Quote
Old 01-22-2007, 01:47 AM   #18
DriftSpecial180
Not true, if you would have looked at the lovely diagram a few posts up...it shows that the stock strut suspension allows more clearance because the strut housing is the only part that the tire can make contact with. With a coilover, the whole assembly is shorter, so now the spring (which has a bigger total diameter) is the part to make contact with the tire
Thank You
Old 01-22-2007, 02:51 AM   #19
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
i have 17x9 +30 infront with silkroads. no spacer. but i have like 2mm to clear the spring on the coilovers. so with a +35 youd probably need atleast 10mm spacers to be safe.
redsuns3838 is offline   Reply With Quote
Old 01-22-2007, 05:44 AM   #20
240silvia
240silvia's Avatar
You do have the 17x9's up front though right???
Also, what size tires are you running.... all around.
Old 01-22-2007, 12:25 PM   #21
DriftSpecial180
yes i'm 17x9 all around. 215/45 falken ziex
Old 01-22-2007, 12:27 PM   #22
DriftSpecial180
I used to have silk roads, now i'm on KTS (Silk roads were way nicer, but unfortunately my car got hit and messed up one Silk). I think the Silk Roads were skinnier to provide more clearance.
Old 01-22-2007, 12:31 PM   #23
LB.Motoring
Thank You
quoted for truth.
Robby Leuer
Old 01-22-2007, 12:35 PM   #24
steve shadows
steve shadows's Avatar
what happened to form = function.
now it seems like everyone with nissnas want function = form....
ie. stretched, slammed ass, jdm tyte yo etc.
eh....
ghey imo.
in fact i dont even agree with running anything bigger than 9 inches on the s13, unless your car has the actualy HP to legitimate its use.
but thats my .02 cents
...so yeah go get some fat ass spacers.
Like Me on FaceBook !
Old 01-22-2007, 12:43 PM   #25
240silvia
240silvia's Avatar
well I've got 4, 9" wheels, so you should be pleased. I'm going to order some 10 spacers and roll with it.
Old 01-22-2007, 12:49 PM   #26
DriftSpecial180
eh....
ghey imo.
Well no one on this thread is wondering about fitting anything over 9"s anyways. I traded my 15x7 rewinds for sportmax's then for work ewing mesh (16x8 +0). I don't think Form = Function, i think its supposed Function>Form.
