the 97 base model came without a rear sway bar, right??? i would like to add one from an se model. is this possible? will i need added hardware such as brackets and bolts?
thanks...
'97 240sx '93 prelude vtec '02 jetta gls 1.8t '04 accord ex cp v6 w/navi |
Nuclear
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ALTERED4 @ July 21 2002,07:47)</td></tr><tr><td id="QUOTE">the 97 base model came without a rear sway bar, right??? i would like to add one from an se model. is this possible? will i need added hardware such as brackets and bolts?
thanks...</td></tr></table><span id='postcolor'> Brackets, bushings and the bolts. It's a direct swap that takes about an hour from start to finish. Just make sure that whoever you get the swaybar from includes the endlinks. The bolts were the only thing I couldn't get from the dealer, I just went to Pepboys and got some new stainless bolts. I had my car there to rotate my tires, so I just ran back and forth until I got the right sized bolt... I believe it's a 12x1.25 bolt.
RACECAR spelled backwards still spells RACECAR |
