... you mean "kouki" turn signals
Very simple instructions:
Polarity does not matter with these turn signals. Cut the the pre-existing parking light/ turn signal connector off of the bulb socket. There are three wires; red/ blue (illumination +), black (ground), and green/ yellow or /black (turn signal). Disregard the red/ blue wire, unless you are using the kouki parking lights. Connect one wire from the turn signal connector to ground and the other to the green/ striped wire for each side. This will retain the factory disconnectability, just incase you decide to change turn signals again. /end |
#6 |
anyone? i verified that the bulb on the type x turn singals is 921, and actually that is the bulb i'm using in my case, but with a different socket.. not OEM nissan, whoever installed type X turn signals did you have a problem with the lights blinking at a faster rate then before?
