Old 01-31-2007, 01:28 AM   #1
g-ride
g-ride is an unknown quantity at this point
Poor running when cold
I let my car (91 240) sit for 3 days in 0-10 degree weather and it wouldnt start today. Then eventually it did and ran like complete shit until it was warm, if i touched the gas it would die. Once it was warm it ran alright but still not great. kinda like a bad fuel filter. Id compare it to a carburated car trying to start in cold weather. Anyone have any ideas?
just did:
plugs
wires
cap
rotor
injector cleaner
cleaned intake manifold
g-ride is offline   Reply With Quote
Old 01-31-2007, 06:40 AM   #2
Blackhat
Blackhat is an unknown quantity at this point
Another thing to check out would be the Air Reg.
Although, if it's not running well after getting warm either that's probably not it.
Blackhat is offline   Reply With Quote
Old 01-31-2007, 07:32 AM   #3
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
hope you had anti freeze in it. or its time for a new motor.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 01-31-2007, 09:08 AM   #4
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
i would say replace the fuel filter and see what happens. But it also sounds like a faulty MAF. You have the tools to test it?
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 01-31-2007, 09:31 AM   #5
LB.Motoring
LB.Motoring's Avatar
Also, chk the IAV (idle air controll valve)
back of the manifold near the firewall
Robby Leuer
Old 02-01-2007, 01:30 AM   #6
g-ride
What the hell? yes i have antifreeze in it.
Ive heard a few things:
IAV
Temp Sensor
MAF (no i dont know how to check it, i have a multimeter)
Another thing is that it ran fine before i did the manifold cleaner and injector cleaner. could that have anything to do with it (possibly fouled a plug)? it doesn't run BAD when its warm just not as responsive.
Its too damn cold to mess with it right now (not my dd) im just trying to think of things to check when it warms up a little.
Old 02-01-2007, 06:40 AM   #7
Dream240
Dream240's Avatar
another +1 on the fuel filter. But also another possibility is a bad fuel injector. The cleaner might have been that last straw.... But do the filter FIRST! Then go from there.
Old 02-01-2007, 06:59 AM   #8
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
when my bros coolant temp sensor went bad, it ran just like you described yours. it was hard to start and it would die if you touched the gas until it got warm. even after it got warm, there was a lot of unburnt fuel coming out of the exhaust.
ladiesman8527 is offline   Reply With Quote
Old 02-02-2007, 11:38 AM   #9
g-ride
The fuel filter is fairly new (<6 months). I was just wondering if maybe the cleaner knocked something loose in my tank and DID clog the filter. I might just go get a new fuel filter and coolant temp sensor.
Old 02-02-2007, 11:50 AM   #10
Dream240
Dream240's Avatar
Well, do you have a fuel pressure tester? If not, I think you can rent one at autozone. Just check it if you can. After thinking about it, fuel pressure test is your first step. Then go from there.
Old 02-02-2007, 11:58 AM   #11
vqboodah
vqboodah's Avatar
vqboodah is on a distinguished road
is it SR or KA? my 240 w/ SR been sitting for awhile and in the cold weather the idle sucked and press on gass it would just bog. when warm weather came, the car ran mint. i think it was just the weather affecting the car. especially since it's been sitting there. how's the gas level on it? if it's low, maybe condensation affected it.
vqboodah is offline   Reply With Quote
Old 02-02-2007, 12:02 PM   #12
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
replace your injectors and clean your aicv
and you should be fine
make sure to replace the pigtails on the injectors
los_inc is offline   Reply With Quote
Old 02-02-2007, 01:18 PM   #13
Dream240
Dream240's Avatar
Just like that huh? Replace them all, and you SHOULD be fine? Sounds like you just like to throw parts at your car and hope it gets fixed. Not a very efficient way to repair your car. The best course of action would be to diagnose your fuel system. Will definitely save you money in the long run.
Sorry but I just call it like I see it.
