Old 02-05-2007, 12:23 PM   #1
mwisniew
mwisniew is an unknown quantity at this point
Need help identiffing a diff
I have a that came out of JDM s14 or s15. The diff has a sensor near the input shaft and the cover has two eyelets near the upper side on the left and right. It has a white spot painted on it. It seems to be a limited slip and has 6 bolt half shafts.
Some one told me that some of the later JDM s14's had this sensor on it and all s15 did. Will this hole pumpkin swap out with my S14?
I don't know if this will help but it came out of a rear sub member that had electronic HICUS.
mwisniew is offline   Reply With Quote
Old 02-05-2007, 12:35 PM   #2
projectRDM
projectRDM's Avatar
S14, same as the US. Could also be a 95-97 J30, or whatever it's called in Japan. The S15 will have dual sensors, one at each output shaft.
Old 02-05-2007, 12:39 PM   #3
mwisniew
What do the sensors look like on the output shafts?
Old 02-05-2007, 12:42 PM   #4
Taniguchi_Is_#1
just open it up if you aren't sure. i would guess that you have an s14 VLSD, though.
Taniguchi_Is_#1 is offline   Reply With Quote
Old 02-05-2007, 01:48 PM   #5
projectRDM
projectRDM's Avatar
It doesn't matter, yours is on the input shaft just like you said, so it's not a 4channel ABS setup.
Old 02-06-2007, 07:42 AM   #6
mwisniew
Thanks for the help.
I did snap a couple pics, so i will go ahead and post them.
http://www.zilvia.net/f/attachment.p...1&d=1170772735
Old 02-06-2007, 08:19 AM   #7
projectRDM
projectRDM's Avatar
S14 for certain, but it's the same unit as the later model J30. The only difference may be the gear ratio, it's either 4.08:1 or 3.96:1, but you won't notice it either way.
