Old 02-23-2007, 01:48 AM   #1
DevLis
DevLis is an unknown quantity at this point
no speed indication,..HELP!!
Yo Guys,
I need help.
My speed indicator doesn't work.
Everything works find of the gauge cluster acept the speed.
I had try to change a new gauge cluster no result and even after install a Apexi RSM speedmeter didn't get any speed info.
Can anyone tell me what r going wrong here, it's talking about a 180sx with CA18det engine.
Thank you,
Ethan
DevLis is offline   Reply With Quote
Old 02-23-2007, 01:55 AM   #2
seekanddestroy
seekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choices
Do you have a service manual? Check to see if the speed sensor in the trans is functioning correctly.
seekanddestroy is offline   Reply With Quote
Old 02-23-2007, 02:22 AM   #3
yokotas13
yokotas13's Avatar
speed sensor for sure
yokotas13 is offline   Reply With Quote
Old 02-23-2007, 02:46 AM   #4
DevLis
Everything works find.
I just have no speed signal.
Old 02-23-2007, 02:52 AM   #5
seekanddestroy
So you are saying, everything works fine, but you have no speed signal?
The speed sensor in the transmission PROVIDES the speed signal, have you CHECKED the speed sensor according to the FSM?
Old 02-23-2007, 03:58 AM   #6
DevLis
I am very sorry, i am just a noob, bought my 180 just a couple months ago.
Could u tell me how can i check the sensor and what is FSM please?
Old 02-23-2007, 03:59 AM   #7
yokotas13
yokotas13's Avatar
google it
we told you the problem, try and help yourself before we hand feed it to you
Old 02-23-2007, 04:05 AM   #8
DevLis
Originally Posted by yokotas13
google it
I have googled a few day now.
And I am still at goolge right now,..haha google rocks
Old 02-23-2007, 04:22 AM   #9
cotbu
cotbu's Avatar
edit .........
Old 02-23-2007, 05:41 AM   #10
DevLis
Anyone more helpfull instuctions?
Old 02-23-2007, 05:56 AM   #11
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
1.Go under your car and look at the trans, it is not hard to find the speed sensor.
2. It's held on with 1 bolt, and its close to the slave cylinder.
3. To test it, measure the output with a voltmeter, personally I would just replace the damn thing.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 02-23-2007, 07:04 AM   #12
cotbu
cotbu's Avatar
Sorry, edited my post because the above info was great!
The post above this show you what the speed sensor looks like, correct? Follow the wires coming from the sensor to see if anything is disconnect or shorted, get a continuity tester. Test the wire, from sensor to connection by firewall to ecu. If the speed sensor checks out OK!
Old 02-23-2007, 08:05 AM   #13
DevLis
Thanks guys!
Will let u know if it's gonna work!
