Old 03-03-2007, 12:26 AM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
idling lasts no more than 10 seconds and dies. What is going on?
I have an idling issue. The idling of the engine, KA24DE, doesn't last more than 10 seconds. It is idling at 600 rpm with some sputtering and slowly dies after about 5 to 10 seconds.
Engine idling is not stable, traveling about 200 - 400 rpms up and down.
When I press or take my foot off gas pedal, engine takes more than 1 second to respond.
What could be causing this?
jafero is offline   Reply With Quote
Old 03-03-2007, 02:29 AM   #2
drftwerks
vac leak
timing
fuel pump
ecu
cas
maf
etc alot of stuff bro
giantroboteyes.wordpress.com/
Old 03-03-2007, 11:21 AM   #3
jafero
Yeah, too many possibles. I have shit load of work to do...
Old 03-03-2007, 03:26 PM   #4
jafero
I just disconnected MAF sensor and ran the engine.
It didn't die. Idling was still at between 400rpm ~ 600rpm and rpm is not increasing when I press gas pedal.
Does this mean MAF is malfunctioning or is wrong MAF?
Old 03-03-2007, 03:30 PM   #5
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
Tell us your setup, Is everything stock? You can test your mafs with a multimeter, it could be your IACV should clean it with some seafoam spraying down the black hose that connects to your intake tube next to the throttle body. Yea and check your vacuum lines for a leak.
240sxScores is offline   Reply With Quote
Old 03-03-2007, 03:47 PM   #6
jafero
My set up is,:
Chassis: 89 s13
Engine: KA24DE, year unknown. Doesn't have butterfly valve inside intake manifold.
Everything is stock.
Disabled EGR but EGR temp sensor is not fitted onto the engine yet.
Disabled FAIRC.
Old 03-03-2007, 04:21 PM   #7
05civse
05civse is making a name for him/her self05civse is making a name for him/her self
s13s use an extra wire to the ecm during "start" on the ignition switch. i wired in a remote start only to the "run" and "start" only and not the second ecm start power and it would do the same thing with my SR. so i guess it could maybe possibly be the ignition switch or fuse in that circuit if nothing else fixes it. just a thought
05civse is offline   Reply With Quote
Old 03-04-2007, 01:15 AM   #8
jafero
I had this problem when I didn't connect dash harness with the engine harness.
I sprayed carb cleaner into IACV and idling became much stronger but still idles at 600 rpm. I tried turning idle adjust screw but nothing changes. Still responds to throttle very slow, about 1 to 2 sec behind to gas pedal pressure.
Old 03-04-2007, 01:33 AM   #9
wordson07
wordson07 is an unknown quantity at this point
i have an idling problem, it just idles rough overall.... but i found where it is, an air hose leak, the one going into my valve cover. dealership wants $40, chaaaaaaaright
wordson07 is offline   Reply With Quote
Old 03-04-2007, 11:48 AM   #10
jafero
My valve cover vacuum hose or IAVC hose are tight. This is really throwing me off.
Old 03-24-2007, 07:44 PM   #11
sifu
sifu is an unknown quantity at this point
did you ever get this problem fixed? i'm having the same problem
sifu is offline   Reply With Quote
Old 03-24-2007, 08:57 PM   #12
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i had a idling problem before but its not exactly the same. my rpm right now is still in 600 once in a while. do this
clean your sparkplug
check your fuel filter
check your air filter
make sure you have clean fuel
check for vacuum leak >>>> start your car then spray some carb cleaner all around with your engine to see if u have a vacuum leak. if your engine responded where u sprayed it then might have a leak somewhere u sprayed it last.
thats all i got in my head right now....hope it helps
Old 03-24-2007, 09:16 PM   #13
RoyalFlush
RoyalFlush's Avatar
RoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura about
this has been covered so many times...lame
RoyalFlush is offline   Reply With Quote
Old 03-24-2007, 09:21 PM   #14
wangan_cruiser
kouki man
Trader Rating: (36)
live with it. even how many times u repost the same sentence saying ITS ALREADY COVERED some people are too lazy to search
Old 03-24-2007, 09:23 PM   #15
RoyalFlush
RoyalFlush's Avatar
^your an idiot.
Old 03-26-2007, 07:29 AM   #16
_shift240
_shift240's Avatar
_shift240 is an unknown quantity at this point
I seem to be having a similar issue, mine will start, but it will immediately stall and die. Redoing the vacuum lines in a few to see if that was the issue. If thats not it, then we will also check the maf and clean it. The air filter is fine, the fuel filter is fine, the plugs are fine, so I'm going to assume its the vac. lines.
Will update later today if I figure out whats going on.
Lia
Signatures are rather overrated...unless its a hot naked chick. Then, maybe, just maybe, it's worth looking at.
_shift240 is offline   Reply With Quote
