![]() Join Date: Apr 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Just Dyno'd my car... I'm a lil weirded out
Here is my dyno sheet from earlier today... My HP mod list is on there.
What I dont understand is how I got this number with stock sidemount, MAF and FPR. (I was running pretty lean but the SAFC fixed that) and yes, it was a 4th gear pull I'm wondering, Do I need to change over to a z32 maf since it was running so lean? I'm in the process of buying another FPR but I'm still stuck between how it was so high and if I'm being robbed of power because of my maf. What are you're guys' opinions? What are other simular SR dyno #s? maybe I'm just crazy but it seems like I'm making more power than I expected haha ![]() |
dynojets run really high.... i ran my car on a mustang and had 220whp and then ran it on a dynojet and had 255whp on the same day... i have similar mods also.. but i have a safc neo and ran 11lbs... but yea i have a z32 maf and 550cc now... i havent yet dynoed it but i think ill run 240whp on the mustang.. when i dyno it again..
#3 | |
![]() Join Date: Apr 2003
Yeah, that sounds like a very optimistic dyno
![]() Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
#6 | |
![]() Join Date: Sep 2005
![]() 1989 S13 ![]() ![]() |
#9 |
![]() Join Date: Jan 2003
wow that is pretty damn high, especially at 10psi? and almost no drop off? i think you should run your car at the track and see what it can do. the trap speed will definitely show you if your car is really making that much power. im guesstimating 240whp in mine and i trapped at 108mph. with 260whp and almost no drop off i would guess a high 12 at 110+ also i just noticed that youre on the stock smic still, which is even more crazy...
TEAM SKIDMARKS Carbon black S13 SR Coupe |
#11 |
![]() Join Date: May 2003
Back out the correction factor, and it's a little less "optimistic":
Look at the chart...it lists the SAE correction as 1.06. 255 / 1.06 = 240rwhp 257 / 1.06 = 242rwhp ............ BUT...what T25 spools to full boost by ~4000rpm and holds until redline? Looks fishy to me (?). - Brian
www.KA24DEvelopment.com |
#12 |
AFC #1
![]() Join Date: Oct 2003
Are you sure that's your dyno and not an S14SR? The fuel looks fine on the dyno. I hope you did more than one pull.
#13 |
LAID OUT
![]() Join Date: Mar 2004
Just noticed you are from Vegas - how much did they charge for your dyno time?
I wouldn't change the AFR you're right around 12 which is decent. I doubt your stock MAF is holding you back, you might see a slight improvement from a Z32 and retune but if you're happy with the #s for now, why screw with it? |
#14 | ||
You know I just forgot I have a megan header. But would that contribute that much? |
#15 |
LAID OUT
LOL hey dude
![]() GL |
#17 | |
yeah, its a t25. Its my old t25 from my redtop that I put on my blacktop. I'm sure everyone is familiar with the Circuit Sports downpipe right? Personally I love the thing. It was worth the money. |
#21 | ||
![]() Quote:
#22 |
AFR should run between 12.7:1~13.2:1........
Timing can be advanced slightly at that AFR. The fuel should cool the cylinder charge to prevent detonation..... FYI something is really wrong with that dyno, redtops with 10PSI T25's are normally around 225WHP, Blacktops about 238WHP...... Are you sure it's not a T28????? |
#23 | |
#24 | ||
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
![]() Quote:
#25 | ||
That's 100% incorrect. A proper A/F for a turbocharged motor is ~12:1 or so AT THE LEANEST. Run +13:1 at ~10-12psi on a SR and you'll HEAR the knock, and possibly break the motor. But don't take my word, I'm not a tuner...maybe listen to Garrett: Quote:
- Brian
#26 |
LAID OUT
DLo, Did I misread your post regarding AFR? I was thinking about this the other day, I believe the "correction feature" on the dyno should only alter the power/tq curves to compensate for temperature/elevation/etc... I don't think the correction should apply at all to the AFR. Really 18's?!?!
#27 | |
I also got to thinking. My low throttle correctiveness is set to 0 with a high throttle setting of 20%. Shoulld I alter the low throttle settings to somewhat match my high throttle settings? Considering it would be hitting 18s at 0 correction on the safc. |
#28 |
LAID OUT
Makes more sense, the timing will raise your EGT and lean the mixture. Also I would try to pick up a wideband kit soon before you start playing around with the safc too much. The stock narrowband o2 sensor is fairly useless anywhere besides 14.7:1 afr, especially if it's getting older. I wouldn't trust it to do my turning on.. The dyno (obviously) have a wideband? Sorry I can't help with the other SAFC question =/
#29 |
ok, question...where are you getting the 18 for the A/F? according to the dyno(which should be ALOT more accurate than a A/F gauge you have on your car) you are at just under 12 which is right where you want to be on a turbo car. You should start off just under 14 at low RPMs then drop to around 12ish when boost kicks in and stay around there. Thats why the dyno graph has a red dashed line at that A/F ratio. And as for the power you are reading it is high for one of a couple reasons. First if you dont have a boost controller you could very likely be over boosting more thatn 10psi...you should really get one if you dont already have one, its much safer. Second the correction factor on the dyno should be the SAE correction (this is the number that everyone gives as the universal HP numbers, it makes the right corrections for temp, altitude, humitidy for your location. And third a dynojet is going to read higher than a mustang dyno. This is because a dynojet mesaures free spining torque with out putting a load on the wheels to simulate being on a road. But a mustang dyno, you have to put in the vehicle weight so the dyno can adjust for the accurate load on the wheels, and this type will give you a lower number because of this but it is a more realistic number, the actual HP you will have on the street. The stock hp for that turbo and engine should be 205hp and 203tq at the crank. The stock turbo will be safe to 13-15 psi. After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage. The engine should produce 230-250 RWHP at safe boost. So your probalby around the 15psi range...well hope thats of some help for ya bro!
