![]() Join Date: Apr 2006
dropped a cylinder rb25det
Ok heres the problem
I hit a bump, and BAM Shit started smoking, adn through elimination its #1 WHen you unplug the fuel injector it is fine, smoke goes away plug it in, smoke city it runs on 5 when i plug #1 injector in, it wants to die in like 2 seconds flat, and will only stay running, barely with some throttle. all 6 plugs have same appearance all 6 cylinders have same compression, wiht no loss within 5 minutes of pressure. i cant figure this shit out. any ideas? I also swapped #1 and #2 fuel injectors, same problem i haevnt done the coil packs yet.
2015 Subaru Outback Overlander - Wagonofdoom |
i was thinking valve also, i got a weird tapping going on. im going to pull the valve covers this weekend when i have more help and the intercooler off for the FMIC changeover....
i gota find a coilpack though....
#6 |
get on AIM fag
#7 |
![]() Join Date: Jul 2003
Why is everyone saying it's the coil? I don't get that at all. He is saying once he plugs in the FUEL is when it starts smoking. Oh yeah, where is the smoke coming from?
I think that there could be a short in the fuel injector wiring and it's keeping the fuel injector on, thus flooding that cylinder and affecting the other cylinders. One bad coil can't do anything to the rest of hte cylinders. And keep in mind that he keeps the coil plugged in the whole time! So I definately think this issue is fuel related. But yeah, got a picture of the bump? lol |
#8 |
![]() Join Date: Jun 2003
if the injector is just pouring in it will make smoke at idle, like white smoke looks like coolant but dosent smell like it. im assuming either ripped injector gasket or bad injector?
edit just saw you swapped injectors. hmm id be 100% positive its not the o rings, ive pinched the o rings quite a few times, but other than that, what everybody else says |
#9 |
LAID OUT
![]() Join Date: Mar 2004
Damn that sucks.
Do a Leakdown test to see if the rings and valve seat and HG are ok. Edit: See you already did a compression check.. When you swapped the injectors, did you leave them both plugged in? Because if the original injector is leaking and you plug it in it'll smoke regardless of what cylinder it's in... Unless you swapped the injector and only plugged in the "new" injector and left the original unplugged on the other cylinder. I would probably send the injectors out for flow testing and ultrasonic cleaning if the leakdown test shows good. GL dude. |
#10 | |
gasdgasdsdgs |
#11 |
LAID OUT
It sounds like plugging the "bad" injector in is whats causing the white smoke. You should find another injector to test with or have your injectors rebuilt with new orings and insulators/spacers.
GL |
#12 |
when i did the injectors
I left the #2 cylinder deasctivated not plugged in so it wouldnt be a factor But it fixed itself today i dont know how But i have 550s and a new coilpack on the way in case.
#16 |
![]() Join Date: Nov 2006
if a coilpack was fucked the car would run like shit. you should be able to feel/hear a stumble throughout the RPM range. and it would smoke like fuel if a coilpack was fried because its not burning the fuel.
95 Zenki-RB25 swap with a couple of things ![]() 95 Zenki-SR on the way |
#17 |
it sa coilpack, we took it off and hooked it up to a tester, and it snot putting out full voltage all the time, i have another one on the way
