Old 01-30-2002, 09:41 PM   #1
DSC
New Title
DSC is an unknown quantity at this point
I know lots of us 240 people have trouble with 3rd gear. what is it? I shift from 2nd to 3rd and its like I just hit a wall, it doesn't go in gear, I have to back it out (into neutral, clutch still in) and push it back in. If i'm shifting really fast i'll let my clutch out and just grind the #### out of it trying to get into 3rd. I just can't take it anymore. I cannot enjoy driving my car if I can't shift smoothly. It did it before and after my short shifter install and with and without a weighted shift knob. My car is a 96 s14 with ~52,000 miles. Please help...
DSC is offline   Reply With Quote
Old 01-30-2002, 09:51 PM   #2
jay
jay is an unknown quantity at this point
I have the same problem, especially when i was racing. Now, I just jam the #### thing in gear if i am shifting fast. I know its not for the tranny but I am getting my SR motor in four months so whatever.
jay is offline   Reply With Quote
Old 01-30-2002, 09:52 PM   #3
luke20
luke20 is an unknown quantity at this point
Mine's a 91 240 FB, and it does exactly the same thing.  It's really shitty.  I kinda thought the third gear syncro was shot, because that's what I went through with my civic (integra LS tranny).  But I know what you mean about it feeling like you're hitting a wall.  You sort of have to hold it against third gear and let it pop in itself.  Or you'll grind.  I would really like to know what causes that.  Have you had any clutch problems, too?
luke20 is offline   Reply With Quote
Old 01-30-2002, 09:52 PM   #4
chickenmanq
chickenmanq is an unknown quantity at this point
I've found third gear can only be attained when 2nd is close to redline, or not close.  There doesn't seem to be much of a middle ground.  Are you shifting by letting up on the clutch pedal as you push it into gear?  I don't know if that qualifies as speed shifting, but it's how I've always shifted.  I don't let the clutch sit disengaged while I'm shifting.  I just press clutch, flip it through to the next gear as I'm engaging the clutch.  So really, the gear is already sort of spinning when I stick it in.  However, it's spinning slow, so it doesn't grind.  Don't know if that helped.
chickenmanq is offline   Reply With Quote
Old 01-30-2002, 10:44 PM   #5
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
do it old fashion style man, double clutch!
or, i've also heard that the redline tranny fluid is really good "i highly recomand this (holding a bottle of redline tranny fluid in his hand), my car don't grind in 3rd gear anymore."  from some guy called Drew, mrmigs's friend who has a 95 or 96 gold or cream 240.
240meowth is offline   Reply With Quote
Old 01-30-2002, 11:09 PM   #6
DSC
New Title
I just don't see how good tranny fluid would stop this problem. If it was just a little stiff I could understand, but it just dosen't go in at all. Even when I really push hard it won't go in, just have to back it out and slip it in.
Old 01-31-2002, 08:32 AM   #7
rampid360
rampid360 is an unknown quantity at this point
Send a message via ICQ to rampid360
I'm driving a 95 s14, but havent experienced many problems yet...so you'll find most of my replies are based on my old car (an 89 z24...)  But i did have a similar problem.  I thought syncro too, but i just bled the clutch and it seemed to solve it.   Simple enough to be worth a shot i suppose
rampid360 is offline   Reply With Quote
Old 01-31-2002, 01:21 PM   #8
BadMoJo
BadMoJo's Avatar
BadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura about
Send a message via AIM to BadMoJo
My tranny just doesnt like to go into gear when its cold, I double clutch until it warms up. Once its warm I have no problems. It usually takes a couple minutes to get warm.
(Edited by BadMoJo at 12:22 pm on Jan. 31, 2002)
BadMoJo is offline   Reply With Quote
Old 01-31-2002, 04:50 PM   #9
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
From what I recall, part of this is caused by having a direct linkage transmission.  We shift with a metal rod so unlike a cable shift you feel the vibration etc transmitted with the shift.  At about 50k miles you're about due for fluid change anyway.  I suppose it is possible you have a bad synchro, or one that is a little worn and made worse by the direct linkage.  Also, do you have an aftermarket shifter or shift knob?  I believe the stocker is counterweighted to reduce the shock that accompanies a third gear shift and helps it to slide right in.  Mine gives me a little feed back sometimes, but not to the point I would worry about it.
If its that bad, double clutch unimportant shifts for a while and get some good tranny fluid like Amsoil or redline.  If that don't work, you may have problems.
240 2NR is offline   Reply With Quote
Old 01-31-2002, 05:19 PM   #10
DSC
New Title
From my inital post. "It did it before and after my short shifter install and with and without a weighted shift knob."
What would cause the tranny or syncros to be worn at 52,000 miles? I'll try to get some good tranny fluid in this weekend I guess.
Also, it doesn't do it every time I go into 3rd just every now and then. Sometimes it will slip into gear but give a quick grind sound (probably my fault on that one)
My problem is mostly at high rpm but sometimes when I'm shifting at 4,000 or so too.
Old 01-31-2002, 07:48 PM   #11
chickenmanq
Have you owned it since it was new?  Maybe someone kept trying to stick in in 3rd going 90?  Or learned to drive on it and killed 3rd?
Old 01-31-2002, 08:05 PM   #12
DSC
New Title
I bought it 9,000 miles ago (5 months) and I learned to drive manual on it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> but I never messed up bad. Just the standard grind here, stall there. It's not seen the revlimiter since i've owned it, haven't even takein it over 85 yet. maybe the previous owner (who bought it newish...2k miles, dealers car) messed it up. I dono though, there are alot of people who say they have troubles with this gear. I was kinda thinking it was something simple...I guess not <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('>
EDIT: I've been driving stick for 5 months (as stated above) do you think my trouble could be a lack of experiance? I don't see how it could be, but I'm just hoping that I really suck and nothings broken <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> Any way I could just be shifting bad? Hitting the edge of the slot instead of going head on? *shrugs* any ideas?
(Edited by DSC at 8:29 pm on Jan. 31, 2002)
Old 01-31-2002, 08:57 PM   #13
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
well, obviously they would not produce the car that way, so it has to be repairable. &nbsp;I would say take it by your local nissan dealership and ask them to check it out for you and see what they think. &nbsp;
Sounds like a worn synchro to me. &nbsp;Also, how is your clutch?if your going liek 25, put it in fifth an accelerate up to about 50 or so with your foot in the floor. &nbsp;Any slippage? &nbsp;Do you have to put the clutch in the floor to shift?
sykikchimp is offline   Reply With Quote
Old 02-01-2002, 10:37 AM   #14
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
I'd say bleed the clutch, and change the tranny oil first. That'd be the cheapest, and hopefully your problem is solved there. Otherwise, I'm guessing it would be a synchro.
transient is offline   Reply With Quote
Old 02-01-2002, 12:43 PM   #15
The Punk Genius
The Punk Genius is an unknown quantity at this point
Are the only people having trouble shifting, the ones with short throw shifters?
The Punk Genius is offline   Reply With Quote
Old 02-01-2002, 02:18 PM   #16
The Punk Genius
The reason I ask is....I was told from a very reliable source not to mess with the stock shifter, because it will throw off the syncros in the tranny. I never knew wether to believe it or not....but after reading this thread I am starting to lean to believeing it.
Old 02-01-2002, 03:25 PM   #17
luke20
Mine's a 91, with a KA24DE, and a stock shifter. &nbsp;It grinds third gear, too. &nbsp;But then again, I have reason to believe there're 226,000 miles on it and the previous owner beat the shit out of it for all those. &nbsp;
Old 02-01-2002, 04:32 PM   #18
DSC
New Title
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from The Punk Genius on 12:43 pm on Feb. 1, 2002
</td></tr></table><span id='postcolor'>Heh, again from my inital post in this topic...
&quot;It did it before and after my short shifter install and with and without a weighted shift knob.&quot;
Also, how do you bleed the clutch?
(Edited by DSC at 4:37 pm on Feb. 1, 2002)
Old 02-02-2002, 09:17 AM   #19
The Punk Genius
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from DSC on 4:32 pm on Feb. 1, 2002
I read your post. What I was trying to determine is if yours was an isolated incident, or if others were having the same problem with and without the weighted knob, and with or without the shifter change.
Old 02-02-2002, 11:26 AM   #20
DSC
New Title
Oh, my bad...thought you just didn't read it. There is a topic on NICO with a lot of people haveing smilar problems but nobody knows what it is.
Old 02-02-2002, 02:08 PM   #21
240racer
240racer's Avatar
240racer is an unknown quantity at this point
when I first got my '89 the shifting was pretty notchy and didn't go into gears nicely. &nbsp;I changed out the fliud (redline MT-90) and now it is much better. &nbsp;Don't know if this will help your specific situation, sounds like your syncros might be pretty worn, but it should help most people that aren't happy with their shifting. &nbsp;If you double clutch that saves wear on the syncros, because that overrides them.
240racer is offline   Reply With Quote
