Old 03-10-2007, 03:55 PM   #1
Shift_Drift_S13
Shift_Drift_S13 is on the path to ruinShift_Drift_S13 is on the path to ruin
s13 Question about stock S13 differential
what kind/weight gear oil should i put in the differential? Is Lucas 75/90w fine?
Shift_Drift_S13 is offline   Reply With Quote
Old 03-10-2007, 04:03 PM   #2
l bricks l
l bricks l is an unknown quantity at this point
should be fine just as long as it's GL-4. putting the wrong GL rating is corrosive to the diff.
l bricks l is offline   Reply With Quote
Old 03-10-2007, 04:42 PM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
automotive gear fluid. Thick and viscous is what you want.
80w90 is good, but you could use 75w90 as well.
SochBAT is offline   Reply With Quote
Old 03-10-2007, 05:26 PM   #4
Shift_Drift_S13
Just went and looked and it said GL5 or GL6..... What's the GL for?
