Old 03-12-2007, 11:19 PM   #1
90S13dude
90S13dude's Avatar
90S13dude is an unknown quantity at this point
Send a message via AIM to 90S13dude Send a message via Yahoo to 90S13dude
3.8 Taurus Fan
Can someone please explain to me the Taurus Fan install. I have been looking at the Houston 240SX forum install but am confused. I do not know where the Hi/Lo relay is. I was told to splice it into the AC Relay but am unsure which wires to splice into. All help is greatly appreciated. BTW I did do a search and found nothing. Also this is going into a 90 240SX.
Chris
90S13dude is offline   Reply With Quote
Old 03-12-2007, 11:40 PM   #2
Akiros
Akiros's Avatar
Akiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfection
Send a message via AIM to Akiros
240sxforums.com has a good writeup, thats how I did mine. the hi lo relay is in the fuse box under the hood, look at the top of the cover. there are three wires coming from the taurus fan unless you have the complete harness which there are five. if you have the harness you can follow the instructions on 240sx forums completely, if not, just touch the wire to the battery while the black one is grounded to find out hi or low and use the stock relays as in the writeup on 240sx forums. I hope I helped, because im somewhat drunk while I typed this, but if you msg me on aim id be able to help you better.
Akiros is offline   Reply With Quote
Old 03-13-2007, 07:01 AM   #3
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
I just used my own relays, put the low speed on one of those cheap t-stat switches from advance auto, and the high on a switch.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
