Old 03-24-2007, 09:56 AM   #1
ZX88
ZX88's Avatar
Angry f&^#K 17mm bolt
im installing my coilovers toady and everything was going good until i got to the front drivers side 17mm bolts i could get the bottom one off but the top one is rediculous ive used pb blaster 4 times on it and its still not moving. anyone know what to do? it has all ready claimed a 17mm socket and wrentch.
Old 03-24-2007, 09:58 AM   #2
projectRDM
projectRDM's Avatar
Impact, if that doesn't work chisel it off or grind it out with an angle grinder.
Old 03-24-2007, 10:01 AM   #3
seekanddestroy
seekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choices
muscles
msg
seekanddestroy is offline   Reply With Quote
Old 03-24-2007, 10:08 AM   #4
StaticX27
StaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond repute
Get someone stronger
Then when you put it back on, put on some anti-seize
StaticX27 is offline   Reply With Quote
Old 03-24-2007, 10:10 AM   #5
gotta240
Fuck getting someone stronger. Why don't YOU(zx88) get smarter?
Go get a LONG(4 foot) "cheater bar". Use a STONG(not breakable) Wrench. The leverage should pop that thing right off.
If that doesn't work try heating the nut(try to keep heat away from the strut).
If that doesn't work, do as stated above...grinder, chisel, etc.
EDIT- i'm wrong, use 6pt
Old 03-24-2007, 10:11 AM   #6
g6civcx
g6civcx's Avatar
Use a breaker bar and 6-point socket. If not, apply heat, cut, or drill.
Originally Posted by gotta240
EDIT- USE A 12pt. socket with this much force... you are likely to round the bitch with a 6pt.
Are you sure?
Old 03-24-2007, 10:15 AM   #7
gotta240
WHY a 6pt? I disagree.
Old 03-24-2007, 10:17 AM   #8
g6civcx
g6civcx's Avatar
I found this in Google in about 3 seconds: http://www.rd.com/familyhandyman/content/19608/
It's consistent with every single source I have seen. What are your sources?
Old 03-24-2007, 10:22 AM   #9
gotta240
Interesting. Thanks for that link, i guess i learned something. For rusted/hard to use bolts i have ALWAYS gone with the 12pt. sockets. As a matter of fact i RARELY use my 6pt because i always thought the 12pts gave me a better "grap". Prob. all in my head! lol. Anyone else do this?
Guess i'll try a 6pt next time.
Old 03-24-2007, 10:27 AM   #10
yokotas13
yokotas13's Avatar
6 point is the way to go mainly becuase you have more surface area gripping the nut/bolt at any given time.
yokotas13 is offline   Reply With Quote
Old 03-24-2007, 10:35 AM   #11
TheTimanator
TheTimanator's Avatar
I've learened the hard way on that. 12pt socket will strip out a rusted bolt/ nut considerably easier than a 6 pt.
Again breaker bar is the way to go. I take a section of my jack handle and put it on wrench when I need the extra levereage.
Old 03-24-2007, 10:40 AM   #12
gotta240
Jack Handle FTMFW.
Old 03-24-2007, 10:49 AM   #13
ZX88
ZX88's Avatar
i tried agian and it came undone without any problem thats weird. i wasnt even trying and it just loosend idk.
Old 03-24-2007, 10:48 AM   #14
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
i tried the "cheater bar" when i had this problem, tried heat, only thing that worked cutting the head off of the bolt and drilling it out. i have extra 17mm bolts from courtesy nissan if you need them.
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 03-24-2007, 11:45 AM   #15
Nachtmensch
Nachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond repute
righty tighty, lefty loosey
Nachtmensch is offline   Reply With Quote
Old 03-24-2007, 03:02 PM   #16
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
^^^ nice....haha did u turn the right way?
lexus baby
5t341tH is offline   Reply With Quote
Old 03-24-2007, 03:56 PM   #17
FRpilot
FRpilot's Avatar
sometimes when i have trouble with rusted stubborn bolts i lie on my back, position the ratchet perpendicular to the ground, and then kick it with my feet.. legs are stronger than arms. and this usually helps bust those fucking nuts and bolts. this was before i had an impact hammer and other tools that i have now though but i still use it from time to time when tools are too far away. sometimes im too lazy to bust out impact, charge compressor, reel hose, change sockets, etc for 1 bolt. i need a hose reel because i just have an air house that i hate to roll back up by hand but those reels cost like $60.
FRpilot is offline   Reply With Quote
Old 03-24-2007, 04:01 PM   #18
Sidewayzzz
Sidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura about
Send a message via AIM to Sidewayzzz
meh, if it doesn't come off after about 10 mins of muscling I bust out the dremel and cut that shit off, then goto Home Depot and get another nut...saves time, had to do that with one of my motor mount nuts.
Sidewayzzz is offline   Reply With Quote
Old 03-24-2007, 04:09 PM   #19
drftwerks
get new bolts NOW.
giantroboteyes.wordpress.com/
