Old 08-22-2002, 07:32 AM   #1
240sx2Nur
240sx2Nur is an unknown quantity at this point
My headlights have yellow discoloration, how do I remove the lense without taking out the whole light and putting it in the oven? And after I cleaned them how do they go back on? Is silicon used?
Nico
240sx2Nur is offline   Reply With Quote
Old 08-23-2002, 08:31 AM   #2
240sx2Nur
I need to know how to get the lense off.
Nico
Old 08-23-2002, 07:56 AM   #3
guidot
guidot is an unknown quantity at this point
Send a message via AIM to guidot
Wet sanding or an extra fine grit rubbing compound will get that off.
-Jeff T. 96 240SX
240SXONE
http://www.240sxone.com
guidot is offline   Reply With Quote
Old 08-23-2002, 07:02 PM   #4
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
What grade sandpaper would you use? 1000g?
thelinja is offline   Reply With Quote
Old 08-23-2002, 08:25 PM   #5
Titan
Titan is an unknown quantity at this point
I've told you once, I've told you a thousand times. Try using toothpaste. I'm serious, I've heard it works really well on removing the yellow.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 08-24-2002, 07:16 AM   #6
240sx2Nur
For the last time, the yellow is on the inside, I need to know how to get the lense off!
Nico
Old 08-24-2002, 04:17 PM   #7
rampid360
rampid360 is an unknown quantity at this point
Send a message via ICQ to rampid360
just use some monkey urine and a dry sea-sponge...It'll take the yellow right out.
J/k...i just had to reply something that helps you in NO way <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
I dont think the lens is meant to come off...however, after looking over it, it seems possible. &nbsp;Just pop the black clips off, and wedge something flat in between the lamp asbly and the lens. &nbsp;(I wouldn't use too much back/forward action force. &nbsp;The plastic lip looks like it would crack pretty easily.) &nbsp;Maybe just tap a screwdriver straight down in between it. &nbsp;
Hope that helps a bit...its the best way I can figure to separate the lens. &nbsp;
If not, I can tell you that taking the entire assembly out, and pouring oxyclean and boiling water INSIDE it will greatly decrease the yellowing. &nbsp;Just let it sit for about an hour...then rinse out.
-Al
For every winner there are dozens of losers. &nbsp;Odds are you're one of them.
rampid360 is offline   Reply With Quote
Old 08-25-2002, 11:53 PM   #8
JpS
JpS is an unknown quantity at this point
odds are, if you have an s14, the yellowing is on the outside. &nbsp;the best way to get it off is to use fingernail polish remover (with acetone) then seal it with a good polish, or you can wet sand it like guidot said, but that's probably unnecessary &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hehe.gif" border="0" valign="absmiddle" alt=':hehe:'>
JpS is offline   Reply With Quote
Old 08-26-2002, 10:22 AM   #9
tnord
tnord's Avatar
tnord is an unknown quantity at this point
1) how does it yellow on the INSIDE? it's not exposed to any contaminants like the outside is.
2) if you were to wetsand it, use 2000 grit sandpaper, not 1000.
3) wetsanding is not neccessary. as said before, buff it with a mild/heavy grit compound.
4) if you don't have a buffer, use meguire's/mcguire's (how the fuck do they spell that anyway?) plastic polish and cleaner.
5) if you don't believe me, piss off.
travis
-who knows he's still convinced it's on the inside, but not sure how that's possible.
tnord is offline   Reply With Quote
Old 08-26-2002, 12:17 PM   #10
Mountainmotors
Mountainmotors is an unknown quantity at this point
As someone who asked for the same info on an earlier post...the yellow is on the outside...if you pop the lense off you will still have yellow on the outside and water on the inside...
and I have now seen this on a TV car show...
polish with metal polish...yep...metal polish...like Mothers or Meguiars....
then come back and finish with a nice plastic polish...
I do believe if you try 1000 grit wet paper you will be buying new lens....
Mountainmotors is offline   Reply With Quote
Old 08-26-2002, 08:56 PM   #11
ibanezxguy
ibanezxguy is an unknown quantity at this point
Send a message via AIM to ibanezxguy
i was cleaning my car up at the shop a few days ago and took some du pont 3812 to mine and it cleaned them up pretty good then i took the metal polish to it and now they are clear. &nbsp;So maybe swing my a paint shop and pick up a small thing of 3812... that stuff also works on taking off any nasty stick crap and its safe for most everything
ibanezxguy is offline   Reply With Quote
Old 08-27-2002, 11:18 AM   #12
thelinja
thelinja's Avatar
will any of these rubbing compounds ruin the paint on the car if you accidentally get some on it?
Old 08-27-2002, 05:10 PM   #13
ibanezxguy
no, not unless its super duty.. but even it wont hurt your paint i just would rub it. &nbsp;But it might not hurt to buff your whole car if your going to do the headlights
Old 08-27-2002, 05:44 PM   #14
tnord
tnord's Avatar
no they will not hurt the car and DO NOT ATTEMPT TO BUFF WITH COMPOUNDS IF YOU DON'T KNOW WHAT YOU'RE DOING (or at least without an explanation on how to do so from me)
Old 08-28-2002, 10:35 AM   #15
ibanezxguy
ya true dat i forgot about the whole if you dont know what your doing you might burn the car...
