Old 05-23-2007, 08:22 PM   #1
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
Brake Master is filled with air bubbles WTF??.. lol
91 ABS s13
aight so i swap on r33 calipers, with conversion lines..
i gravity bled them the first time.. and they felt ok... but not 100% perfect. i then bled them normaly.. and the pedal dies.. dead... no pressure
then i relized their was air bubbles coming from the MC, as if u put a straw in it, and then blew bubbles, every time the pedal was pressed. (bubbles never end)
i cant bled the system out, i dont know what the problem is.. i tryed bleeding them out for an hour.. nothing, the MC makes FOAM! mad Air!.. i have never seen anything like it..
any ideas?
Chrischeezer is offline   Reply With Quote
Old 05-23-2007, 08:25 PM   #2
johngriff
johngriff's Avatar
this is going to get messy if you do it with the M/C in the car.
Open all 4 lines on the brakes. Slowly stroke the MC/Pedal unitl you get flush fluid. You are going to go through alot of fluid.
Or, pull the MC and bleed it on the bench.
[email protected]
Old 05-23-2007, 08:37 PM   #3
speedstar01
speedstar01's Avatar
speedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the rough
+1 for the bench bleed!
speedstar01 is offline   Reply With Quote
Old 05-23-2007, 10:10 PM   #4
ixfxi
Guest
Posts: n/a
yep. bench bleed FOR THE MOTHER FUCKING WIN
yeah KANE!
Old 05-23-2007, 10:38 PM   #5
projectRDM
projectRDM's Avatar
Also you should know that to properly bleed an ABS equipped car the actuator unit must be unplugged. As long as it's powered it will try and fight the pedal engagement.
FORMERLY R240NA
Old 05-23-2007, 10:45 PM   #6
zoototheyork
zoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choices
make sure ure banjos arent pissin really small, try and find some fluid on something before you take the masterout
zoototheyork is offline   Reply With Quote
Old 05-24-2007, 12:26 AM   #7
bardabe
bardabe's Avatar
do that, or u can hit up my friend (Indolent) he has non ABS brake lines if you wanna convert to non ABS car. that will really help you right there
Review Thread
bardabe is offline   Reply With Quote
Old 05-24-2007, 01:32 AM   #8
ixfxi
Guest
Posts: n/a
> Brake Master is filled... 05-23-2007 09:45 PM Friends call me Kanye, but my plastics call me Kane!
haha i gotta know... who wrote this?
Old 05-24-2007, 06:02 AM   #9
qwikspool
qwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfection
Send a message via AIM to qwikspool
bench bleeding ftw.
qwikspool is offline   Reply With Quote
Old 05-24-2007, 04:47 PM   #10
Chrischeezer
thanx for the replies
ok so im going to bench bleed a new MC i got.. but that still doesn't explain where the air is coming from.. it never ends.. every time i press teh pedal down air bubbles shoot out... wtf..?
i checked my new lines with my r33 calipers.. nothing seems to be dripping.. or wet...
