Old 05-25-2007, 01:43 PM   #1
drift_wood
drift_wood's Avatar
drift_wood is on a distinguished road
SR20 problem ran fine, then.....
Hey guys need some opinions on what happened. I searched for days and but cant figure it out.
I just moved to San Diego and towed my car from San Jose. the car was my daily driver in San Jose with no problems ever. I pull the car off the trailer this morning and drive it to go fill it up with gas because it was really really low, filled it up then on my way home I was in third gear and the RPM jumped a little then the car shut off. I tried starting it, and it turns over but doesnt fire up. It is acting like I ran out of gas but its got a full tank.
thanks for the help in advance, Im just hoping that Its not this San diegan voodoo.
Im running a SR20det stock with walbro 255 fuel pump. and besides bolt ons thats it stock ECU and everything.
I am thinking its a fuel pump or filter... but when I turn the key the fuel pump does prime. And recently at home in SJ when I would turn it off I would hear a noise like a wine from the fuel pump so maybe its priming but is just toast, also I did run it pretty low on gas so I could have picked up some shit off the bottom of the tank..
Anyways thanks guys
drift_wood is offline   Reply With Quote
Old 05-25-2007, 02:00 PM   #2
drift_wood
drift_wood's Avatar
need a bump, does anyone know of good shops to take my car to in San Diego, near the Encinitas area
Old 05-25-2007, 02:07 PM   #3
jrmiller84
jrmiller84's Avatar
jrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond repute
Send a message via AIM to jrmiller84
If the car just shut off it might be the fuel pump or an electrical problem somewhere. Check your fuses, maybe the ignition fuse popped for some reason.
BitDestroyer.com
jrmiller84 is offline   Reply With Quote
Old 05-25-2007, 02:20 PM   #4
drift_wood
drift_wood's Avatar
thanks bro, yea Im gonna go check the fuses. Its about a mile away from my house on the side of the road, If it were to be the fuel pump, how hard is that to replace, and can I do it on the side of the road. Could it be my ecu is fried or would that cause more of an issue than just starting.
Old 05-25-2007, 02:24 PM   #5
jrmiller84
jrmiller84's Avatar
I'm not so sure I would jump to the fuel pump right off of the bat. There is a fuse for the fuel pump, check that as well. How old is the pump?
Turn the car over a couple times and take one of the spark plugs out. If it smells heavily of gas it's not your fuel pump. There's a write up in my s13 build in my sig on how to change the pump if for some odd reason it died.
BitDestroyer.com
Old 05-25-2007, 02:27 PM   #6
CA18_S13
CA18_S13's Avatar
CA18_S13 is a well-known jackass
You check your coilpacks.
CA18_S13 is offline   Reply With Quote
Old 05-25-2007, 02:29 PM   #7
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
Originally Posted by jrmiller84 View Post
I'm not so sure I would jump to the fuel pump right off of the bat. There is a fuse for the fuel pump too, check that as well. How old is the pump?
and here it is:
http://www.zilvia.net/f/showthread.p...tall+fuel+pump
i have it bookmarked jrmiller84....love the s13 build thread...its helping me with my sr swap
ecuastyle84 is offline   Reply With Quote
Old 05-25-2007, 02:32 PM   #8
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
I'd hurry up and get the car towed home, last thing you need is some douchebag fucking with your car.
MegasquirtCA is offline   Reply With Quote
Old 05-25-2007, 03:42 PM   #9
slider2828
slider2828's Avatar
Yup I'd tow it, but sounds like a fuel pump. If you put in a walbro and it was really really low, you can overheat and blow it
Old 05-27-2007, 12:18 PM   #10
drift_wood
drift_wood's Avatar
I took the fuel line off the fuel rail right after the fuel filter and turned the key and it sprayed fuel all over the place. So I determined that its not the pump or the filter, I am talking to a guy named mark who owns a shop in El Cajon and he thinks it might be he ignitor, anyone know anything about this.
Thanks for all the help to guys.
