Old 05-31-2007, 11:25 AM   #1
qzhonda450r
qzhonda450r is an unknown quantity at this point
car starts but dies. HELP!!!
i have a 1990 hatch and i put in a 90 sohc engine in it. it starts up if i put some carb cleaner in it but then it dies in about two seconds. a friend told me that it could be anything even the ecu. i changed the ecu from a 10 to a 14 but it still reacts the same way. any help on what i should try.
qzhonda450r is offline   Reply With Quote
Old 05-31-2007, 11:35 AM   #2
twofortyrida1388
twofortyrida1388's Avatar
twofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura about
I know what it is. I had same problem up until yesterday. Make your own fuel gauge or buy one and put it on after fuel filter and you should be getting about 35+ psi when it primes and 40+ revving it. Then put it on before fuel filter and see what it says. If still low like 19 which is what mine was getting its more than likely your pump. I put a new pump in and filter and made sure timing was right and boom the car runs better than ever. Oh and make sure your getting spark as well.
Boost Coming soon...
twofortyrida1388 is offline   Reply With Quote
Old 05-31-2007, 11:42 AM   #3
qzhonda450r
i just got a walbro so ill throw that in and see what happens. i check spark and fuel and i was getting plenty of fuel but ill give it a try.
Old 05-31-2007, 01:24 PM   #4
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
edited. disregard this post!
s13gold is offline   Reply With Quote
Old 05-31-2007, 01:53 PM   #5
CA18_S13
CA18_S13's Avatar
CA18_S13 is a well-known jackass
It could be a distributor or ignition module too. I had that happen to me.
CA18_S13 is offline   Reply With Quote
Old 05-31-2007, 04:24 PM   #6
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
may not be your ignition since it starts when you add gas in it...
check your fuel pump fuse... if its blown then the baffels in your gas tank is causing your fuel pump to short..... take those baffels off....
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 06-01-2007, 11:27 AM   #7
qzhonda450r
where are the baffles in the gas tank. i think i know wat your talking about but i want to make sure before i take the wrong part out.
Old 06-01-2007, 12:38 PM   #8
twofortyrida1388
Try spraying carb cleaner in it as soon as you start it (will take two people) and if it runs while spraying and dies when you stop its a fuel issue.
Old 06-01-2007, 12:58 PM   #9
swayray
swayray's Avatar
they are steel walls about 3" in height and its looped all around the tank... if you noticed some loose... then those are the ones you pull out... they are only held by zipties....
Old 06-04-2007, 11:41 AM   #10
qzhonda450r
the fuse doesnt short out. and i tried spraying it while starting it and it just died out like usual. anyother suggestions on what could be going wrong?
Old 06-04-2007, 12:05 PM   #11
swayray
swayray's Avatar
if your car starts only when you spray... then your ignition should be ok... did you check/replace the fuel lines running through your engine bay? did you check the fuel pressure? you can get a fuel pressure guage at kragen or autozone or something...
