SR hesitation, stumbling, breaking up..
hey guys.. under full throttle especially in 3rd gear, once my car hits 4500 rpm it starts breaking up and losing power. occasionally in 1st even with partial throttle, it breaks up real bad past 3k rpm. when i shift under full throttle into the next gear the motor hesitates terribly, then takes off again. to start.. here are my mods..
z32 maf aeromotive fpr apexi suction kit apexi power fc apexi n1 dual hks w/g actuator forge unos mbc blitz fmic tomei exhaust mani mr turbo outlet, dp 4ply silicone coupling, tbolt clamps i changed the o2 sensor and spark plugs(ngk iridiums, HR 7) 1 month ago. fuel filter was changed about 2 months ago. i thought it might have been a boost leak, so i reinstalled all the couplings and clamps and have them tight as shit now.. everything checks out with the boost. i also had a similar problem when my mafs ground was kinda shitty.. so i redid the ground.. still having the problem.. cleaned the mafs sensor, and plug. the breaking up started a few weeks ago, right after i did the aeromotive fpr kit from enjuku, but i didnt think much of it. at first the pressure was too high causing my car to sound like a lawn mower. after i redid the couplings, vac dropped causing the pressure to lower.. so i raised it back to 45psi. fuel pressure is set around 45psi w/o vac. off of the intake manifold as a vac source, i have the FPR and boost gauge hooked up together. at idle, my vacuum reads .65-.68 bar, and for whatever reason occasionaly dips to .60-.62. im at a loss here.. to the best of my knowledge everything should be solid. do you guys have any idea of what else i can try??? to test my aeromotive fpr, can i turn the pressure all the way up, hook up my factory fpr, and see what happens?? i dont know what to do =( someone please help... -Bart |
did you tune your power fc yourself? or did you have it tuned by a pro? it soundsl like your fuel starts to be lean at 4500 rpms...
http://www.thenismoshop.com |
#5 |
yea it was tuned a while back, before i did most of these bolt ons. im going to dentsport on the 16th. i didnt think the mods would cause such an adverse effect.. most of the problems occured coincidentally around the install of the fpr.. although other stuff could have gone bad since then. car ran great before.. maybe the aeromotive fpr is bad? do you guys think i should seperate the vac sources? damn pfc..is there any way to get this thing to spit some codes?? is there any way to test coilpacks? im swapping mafs and coil packs sunday to rule those out..
-Bart |
#6 |
![]() Join Date: Jun 2004
You can test continuity of the coil pack wireing. You can also use a infared thermometer to measure the coil pack temp.
Did you check the base fuel pressure after the install?
[email protected] |
#8 |
yea i hope the motors not running lean
![]() ![]() -Bart EDIT: yea i checked fuel pressure.. i have it set around 45psi.. my dick head friend reset my power fc map so im back to the old one for a little while now. ive just been increasing inj. 10%... been running fine so far, till this bs popped up -Bart |
#9 |
check all basic maintance first, ground, wired, plugs , make sure they are all nice and tight and connected. Then go from there.
I almost bought a new clutch, asumming my clutch was slipping and it ended up to be my loose TPS sensor. DUH, but yea doublecheck.
#10 |
![]() Join Date: Oct 2004
Wait FPR should not be at 45, it should be around 55psi. Secondly, turn off the boost controller to see if there is stumbling or buckling happening. If there is no buckling when mbc is off, then it is a tuning issue. Thirdly, read the tips off your spark plugs, powdery white = too lean, black/sticky = too rich, and oily means timing is off. You have no one that can lend you a coil pack?
#11 |
stock fuel pressure is between 45-49 psi... how much are you boosting?
#13 |
What is the Rate of the Aeromotive you got? If its like 2/1 you might have your answer right there.
[email protected] |
#16 | |
![]() Quote:
