#6 |
heheh... the other guy at the other tread has the same problem but w/ a stock one...
check to see if the baffels in your gas tank is loose... if it is... then its what's causing your short... otherwise... check the two wires you hooked up onto your fuel pump... its best to use terminal connectors on those rather than electrical tape.... make sure you do not have a fake walbro fuel pump... check for authenticity... the fake one give you problems like this all the time...
http://www.thenismoshop.com |
#8 |
ok... but if you have the same problem again... you know where to look...
btw... no... you use the same size fuse....
