Old 06-12-2007, 11:59 AM   #1
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
S14 SR20DET F4 Pinout
I CANNOT find a freaking F4 Pinout for the S14 SR Harness. Its the same plug as the F3 plug on the S14 KA24DE Harness. But its the SR equivalent. I need this pinout to wire a S14 SR20DET into an S13 Chassis.
I plan on doing a very very detailed S14 SR -> S13 Chassis Wiring writeup.
I searched over 4 hours last night. : /.
Monooxide is offline   Reply With Quote
Old 06-12-2007, 12:46 PM   #2
nismolvr
nismolvr's Avatar
nismolvr is an unknown quantity at this point
nismolvr is offline   Reply With Quote
Old 06-12-2007, 01:02 PM   #3
nismolvr
nismolvr's Avatar
SR F4
Pin #
Color
Function
1
Purple
Wiper Amp INT VR
2
Blue / Yellow
Wiper Amp INT SW
3
Blue
4
Yellow
5
Yellow / Green
Speedometer (VSP)
6
7
8
Green / Black
CONSULT (SCIRX)
9
Black
10
Black
CONSULT GND
11
Black / White
12
Green / Orange
NEUT
13
14
15
Green / White
CONSULT (SCICLK)
16
17
Green / Yellow
Triple Pressure Switch (ACRLY)
18
Green
CONSULT (SCITX)
19
Green / Red
CONSULT (CHECK)
20
Orange / Blue
Cooling Fan (RFRL)
21
Red / Yellow
22
Black / Yellow
Fuel Pump (FPR)
23
Black
Boost Pressure Sensor (GND)
24
Light Green / Red
Boost Pressure Sensor (AVCC)
25
Red
IACV-FICD Solenoid (AIRCON)
26
27
Orange / Black
Wastegate (WSG)
28
Orange
Malfunction Indicator (LED-R)
29
Brown
Power from IGN SW30
Orange / Blue
Start Signal (STSW)
31
Black / Yellow
IACV-AAC Power
32
Red
Power
33
34
35
36
37
Blue / Red
IACV-FICD from AC RLY
38
Gray
39
White
Boost Pressure Sensor (TPRES)
40
Black / Red
IGN Coil RLY
41
Brown
Wiper Amp Off and INT SW
42
Light Green / Red
Wiper Motor Low
43
Light Green / Black
Wiper Motor High
44
Light Green
Wiper Power
45
Pink
Wiper Amp Wash SW
46
Blue / Red
Injector Power
47
48
Black / Red
Ignition On or Start (IGNSW)
NOTES
  1. Items in GREEN are taken from the 1995 SR FSM and verified to be the correct color only
  2. Items within ( ) under Functions are ECU pin name
  3. Pin 9 is listed as being Green / Yellow for Side Turn Signal RH
  4. Pin 16 is listed as being Green / Black for Side Turn Signal LH
  5. Pin 35 & 36 are listed as being Black / White for Camshaft Position Sensor
  6. Pin 26 is listed as being Red / White from IGN #1 to Power Transistor
  7. Pin 16 is listed as being Red / Yellow from IGN #2 to Power Transistor
  8. Pin 7 is listed as being Red / Green from IGN #3 to Power Transistor
  9. Pin 11 is listed as being Red / Blue from IGN #4 to Power Transistor
  10. Pin 36 is listed as being Red / Yellow from IGN Coil #1 to Power Transistor
  11. Pin 35 is listed as being Red / White from IGN Coil #2 to Power Transistor
  12. Pin 34 is listed as being Red from IGN Coil to #3 Power Transistor
  13. Pin 33 is listed as being Red / Green from IGN Coil #4 to Power Transistor
  14. Pin 38 is listed as not having a color and going to TPRES
  15. Pin 26 is listed as being Blue / Green for Cooling Fan (RFRH)
Please send corrections to [email protected]
Old 06-12-2007, 01:32 PM   #4
Monooxide
Monooxide's Avatar
hmmm
Where is the Black/Pink wire for the Fuel Pump Relay?
Where is the Red/Black for the ECU Relay?
Where is the Yellow/Red for the Tach Signal?
You have Brown as the IGN SW30, I have that as the O2?
You have the Orange as the Check Engine Light, I have it as the IGN Start.
Pin 4 is Yellow, I have Yellow as "Water Temp.".
You have Black/Yellow as the Fuel Pump, I have that listed as the IACV.
Iunno, whats the deal but doesnt seem to accurate to me. From the info I have.
