Old 08-19-2002, 09:38 PM   #1
GamblerZ
GamblerZ's Avatar
GamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enough
Send a message via ICQ to GamblerZ Send a message via AIM to GamblerZ Send a message via MSN to GamblerZ Send a message via Yahoo to GamblerZ
I think its time to replace the OEM bushing with something a little more performance minded.  This comes about because I just blew a tension rod bushing.  I like the Whiteline bushings, but they have to pressed in.
Meanwhile, I was looking to get either the ST sway bars or the Whiteline sway bars.  These will come with their own poly bushings.
So, my question is...should I get the remaining set of Whiteline bushings or go with the Energy Suspension kit?
I need bushings but I don't know where to begin.  Suggestions and experienced insight are certainly appreciated and valued.
Visit WTI - WestTexasImports.net
GamblerZ is offline   Reply With Quote
Old 08-20-2002, 08:40 AM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
most of the Whiteline bushings do NOT need to be pressed in.  The rears are two piece actually...you can do it by hand (if you're strong) or with a bench vise.  And the difference between Whiteline and ST or Energy is probably nil.  It's just a piece of urethane replacing the OEM rubber.  Pretty much the simplest design possible.
The Whiteline bars come with bushings.  ST do not.  And Whiteline are adjustable.  ST are not.  And Whiteline fit with N1 dual.  ST do not.
What else?
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-20-2002, 08:50 AM   #3
bbp
bbp's Avatar
bbp is an unknown quantity at this point
I agree with Eric.
Whiteline offers eccentric bushings for the rear to correct camber, but not not have a front lower control arm bushing.  If you want all-out race car performance I can give you the name of a guy who will replace all of your poly/rubber bushings with spherical bearings.  It is costly but can't be beat for racing/handling application.  Probably not a good idea on a street car.
The hardest part is getting the stock ones out.  Pushing the new ones in is the easy part.
bbp is offline   Reply With Quote
Old 08-20-2002, 10:02 AM   #4
GamblerZ
GamblerZ's Avatar
1. Does anyone know what bushings the Energy Suspenion "Hyper-Flex" System comes with?
2. Does Whiteline offer a one-stop bushing kit, or do all the different bushings have to be ordered separately?
3. Which bushings do you recommend replacing in particular?
4. While I am pretty sold on the Whiteline sway bars, are the adjustables worth it?  Or, are they one of those items you set and usually forget about?
5. Does anyone have alternate recommendations for the bushings or sway bars?
Thank you for your patience.
Old 08-20-2002, 10:35 AM   #5
rrx
rrx is an unknown quantity at this point
I have a set of whiteline swaybars on my S14. They work well, but the included endlinks leave something to be desired.
rrx is offline   Reply With Quote
Old 08-20-2002, 11:04 AM   #6
uiuc240
uiuc240's Avatar
No idea.  Sorry.
If you get the "Works" kit, that comes with the bushings, but it comes with shocks and springs too.  I believe the "Handling Pack" is swaybars and a bunch of bushings.  Go to www.whiteline.com.au and check out the site.  All kinds of good info.  You can order direct...that's what I did.  Saved tons.
Lower Control Arm bushings
Tension Control Rod bushings (you did already?)
All the rear link bushings
Subframe bushings are a maybe...but subframe spacers are a great idea.
Adjustable is a great idea.  You can set it up how you like it.  But yes, you will probably set-and-forget once it's how you like it.
Not really.  I am a Whiteline lover.
Eric
2002 Mazda Protege5
Old 08-20-2002, 11:17 AM   #7
bbp
bbp's Avatar
I would go with the Whiteline stuff (I did&#33<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>. &nbsp;Call Don at PDM-Racing.com &nbsp;He will get you hooked up and he is very knowledgeable about what you will need. &nbsp;
The adjustable sway bars are nice, why not get them the cost is about the same.
There really is not many other solutions other than JDM &nbsp;stuff, but I don't think it would be worth the money.
Old 08-20-2002, 01:12 PM   #8
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (bbp @ Aug. 20 2002,09:50)</td></tr><tr><td id="QUOTE">I agree with Eric.
The hardest part is getting the stock ones out. Pushing the new ones in is the easy part.</td></tr></table><span id='postcolor'>
Are you saying Whiteline doesn't have an eccentric LCA bushing, or they don't have LCA bushings at all? &nbsp;If it's the latter my LCA will disagrre with you since it has a whiteline LCA poly bushing in it right now. &nbsp;If it's the former I think you are right though I never looked for one.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 08-20-2002, 01:28 PM   #9
bbp
bbp's Avatar
I am/was not aware of a whiteline bushing for the front lower control arm (S14), eccentric or not. &nbsp;If there is, great! &nbsp;I need to order a pair! &nbsp;I am going to check!
Old 08-20-2002, 01:32 PM   #10
uiuc240
uiuc240's Avatar
Whiteline P/N SPF1483K (Lower Control Arm bush kit - S14).
$124.79 (AUD) = ~$68.00 USD before shipping. &nbsp;See what Don can do for you.
Eric
2002 Mazda Protege5
