![]() http://www.dmhperformance.com/ecutout.htm
what do you guys think about this? a bypass valve thats installed before the cat. so you can still have your stock exhaust with that aftermarket deep throaty sound...whats your guys opinion on this product...im thinking about getting this...do any of you guys out there have this on your 240??? ![]()
#5 |
![]() Join Date: Jun 2004
This is worthless. You WILL lose power vs the stock exhaust, unless it is clogged, in which case something would be broken, and should be repaired.
Your Engine is designed and timed for an exhaust system over 10ft. The length of an exhaust system is incredibly important to the vacuum/scavenge effect, which increases horsepower and lowers exhaust temps. That is it. There is no other way around it.
[email protected] |
#6 |
ok cool...thanks guys...thanks for not clowning on me...and btw..i do have an after market exhaust...im just tired of the cops eyeballing me and smog is a hassle...
#7 |
I havent had experience with them on my 240, or an NA car for that matter, but I have on my previous car.
I had a stock LS (1.8l non-vtec) powered Civic with a homemade turbo kit. It was a fairly small turbo running 9-10psi. I dyno'd with a 2.5" cutout closed at 178whp and 206whp with the cutout open. Im well aware of the scavenging effects tuned exhausts are designed to have, but the magnitude of the gains from a e-cutout are really dependent on the motor setup and how restrictive the previous exhaust is relative to the cutout. As for DMHPerformance, my cutout endured 2 new england winters and a handful of "bottoming out" experiences. The only problem i had with it is that the electric motor is capable of torquing itself and breaking its own mounts. If you avoid from holding the switch too long to open it when its already open then you wont have that problem, otherwise you can rely on the warranty. (a warranty dmhperformance honored with no questions asked.) -Kris |
#8 | |
![]() Quote:
#9 |
The scavenging effect is a good point, but is only valid to a certain point. When there is a completely open space for exhaust to travel, i believe it beats the scavenging effect.
If you wanted to get really anal about it, you could attatch a strait pipe to the cutout, helping the "scavenging" effect. I also have trouble believing the engine was "designed" for a 10ft exhaust, and timing is any different. I'm not saying its not true, i just can't see how anything would change with different length exhausts as far as timing is concerned.. Again...not claiming to know this as fact...i simply can't see how it would be true though... School me. |
#10 | |
Man w/ CTSV & a Car Seat
If you already got an exhaust then get the Apexi Exhaust Valve thing, it works, i know people around me who got them. ![]() |
#13 |
At the end of the day, I can only offer my opinion based off of knowledge and experience.
This is a great starting point, if you are still trying to figure things out, its only $20 which is less than a cutout or an exhaust system. http://www.amazon.com/Scientific-Exh...2226134&sr=8-1
[email protected] |
#14 | ||
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Loose power, really? Ever ran an open down pipe? Significantly higher top end vs having a oem catback. Same idea, except you can control exactly how much is opened. I see what your saying. The outlet is an over kill... kind of like having a 5" exhaust or something ridiculous. But again, you can control how much the valve opens. It all depends how much air there is going toflow. That means, its only most efficient at one point in the RPM range no matter what... for instance the stock 2.25" ID exhaust provides better low end power, where as if you switch to a 3", you imediately notice you loose that low end but you gain significant top end. As far as our cars are concerned, i would be pretty safe to say that we all would like an increase in the top end. I had a Q-tec e-cut out and it worked great if you live in an area where exhaust is a big no no. I was getting pulled over about once a week (always Fri-Sat night) with my Apex N1 like 3 years ago until i switched to a cut out with an OEM cat back. Havn't been pulled over since for exhaust. A friend of mine has a cut out in his 240 also. He has a funny story of him driving down some back roads real fast with the cut out open and passing a cop going in the opposite direction. He noticed the cop turned around to pull him over and he switched the cut out. The cop tries to argue that his stock S14 exhaust is aftermarket but dosnt give him a ticket. He was obviously in confusion after he forced him to rev up lol. Anyways. I switched back to a ricer can only because my S13 is a drift car and tracks require a muffler. I have my cut out and my down pipe sitting in my garage. If your intersted in buying it, LMK. i'll give ua good deal.
HouseBuyers365.com Quote:
#15 | |
![]() Join Date: May 2007
Location: Azusa, socal baby! why do i live this way?? it must be the money!
you are a idiot.. like most people on ziliva.. I run the same setup on my built ka-t but the QTP one. Just make sure you put it has close to the muffle as you can. On the dyno at 5.6 psi I did 205rwhp with the cutout closed and 241rwhp with it open.. With a gutted cat... Cops dont even look twice at me..
NismoKnights ![]() Terrorizing Honda crews since 2003 ls2 powered kouki..all show and GO! putting it down on the streets and the track! LMAO V8 Nismokights on http://www.youtube.com/user/NismoKnights ![]() |
#16 |
If you have a turbo car ATP has one that activated by boost.
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS |
#17 |
You've got to be kidding me..... I'll post tomorrow..
[email protected] |
#18 | |
on a typical SR setup: 198 peak WHP closed. 238 peak WHP open... mind you dynos are not accurate. They are precises but not accurate.. plus atm conditions are a huge variable.
#19 | |
![]() Quote:
HTML Code:
apexi-usa.com |
#21 | |
LAID OUT
![]() Join Date: Mar 2004
This book is a little more modern and covers some more advanced topics inc intake and exhaust dynamics: ![]() If you must run some kind of throttle plate in the exhaust, I think the Apexi deal is the WTG. |
#22 | |
I like that book as a starting point, because it cover the absolute basics. Sections pertaining to wavelength and design are among the best practical explanations I have found. There are better more updated books, with the info presented in more of a practical manner, but they work off a foundation of known truths that I don't think all people may be in touch with.
240whp. Well GTFO out of here. Man that is so much power. and from 205 to 240! I wonder where the restriction was? ![]() Oh right there, the horrid multisize crush bend. Quote:
Now to get down into the mud. Honda Crews since 2003? With 240hp. You've got to be kidding me. I have met a couple of you guys, and you were all really nice, which is why you strike me as something else.... Is this you? http://www.youtube.com/watch?v=pB76eJDp3Js Getting stomped on by a honda on manville? Ricky Racer street racing bs doesnt go very far. I was doing that in the 90's while you were still in middle school. Get a full 3 inch cat back, it will serve you allot better. Why length is important. While the volume argument might make sense, and evacuating exhaust sooner might seem like a gain, it is not. Enough cannot be said for a properly tuned pipe. Exhaust travels through a pipe in a wave length fashion. In that wave there are high frequency points, and low frequency points. These are pockets of high pressure and low pressure. These pockets of low pressure act as a vacuum to the high pressure wave, accelerating their exit from the exhaust. If the pipe you use is too short, the exhaust will not build enough velocity on exit to maintain this effect. Too long and it will loose energy and create a dead zone or back pressure. There is a balance to this effect as well, when dealing with the CFM of exhaust output vs the diameter of piping. From the drawing board, engines are optimized using cam/valve timing for a specific length of exhaust. The easiest way to work around modifying the length of the pipe is to adjust the cam timing. The added benefit of utilizing a full length exhaust in a turbo application is transient response of the turbine and rate to full speed of the turbine. The vacuum/scavenge effect will keep the turbine at a higher rate because the exhaust flow in the pipe is literally pulling the exhaust past the exhaust wheel. In a naturally aspirated application, the length is playing the same role, but fullfilling what could be a much more necessary need, exhaust/intake stroke overlap. The point at which the intake and exhaust valve are open is overlap. At this point in the cycle the temp/pressure of the used fuel/exhaust gas pull out of the chamber, while fresh intake/fuel air mix is sucked in. The scavenge effect greatly increases this effect by pulling the exhaust out of the chamber, and at times sucking through intake/fuel mix. Besides completly cleaning the chamber of excess exhaust, the cool intake/fuel mix enters the exhaust port in the overlap, cooling the exhaust valve, header and system. This leads to a lower likely hood of detonation in an N/A application because of a red hot exhaust valve. Hopefully I broke it down for you hommie.
[email protected] |
#23 | |
with a specific camshaft, head design, compression ratio and tune, yes. But...with an EMS, high lift cams, and dyno time, you can tune for any length and style system your heart desire (maybe some machine work too). I used a cut-out for drag apps back in the day. I had it half way down the exaust. It definitely had a negative effect on torqueand low end power but the higher ranges of the motor where exaust gas and movement of air was faster there was less effect and one a dyno more power. There are plenty of people using t-cut outs on their cars for street racing or drag cars but if your doing a response oriented setup with anything other than a built head and ems, stick to a full length exaust with a muffler to meet your sound needs. It will be mroe beneficial for spool time scavenging etc.
Like Me on FaceBook ![]() |
#24 |
Right, but they are talking about, "throwin some cuttouts on dis bish"
[email protected] |
#25 | ||
The crush bend is factory, that’s why I put the cutout right before it.. You said the cutout is worthless in your first post that’s the only reason I posted.. The cutout is the best thing you can buy period.. Quote:
Like I said that was only at 5.6psi… wtf do you think I do at 20psi+?? Quote:
Yes, that is me.. that Honda has 503whp, if you look at the other video that is linked from that video you can see clearly that I spinning/getting sideways instill top off 3rd.. so wtf is your point? If you want to do it from a line PM me simple..
NismoKnights ![]() Terrorizing Honda crews since 2003 ls2 powered kouki..all show and GO! putting it down on the streets and the track! LMAO V8 Nismokights on http://www.youtube.com/user/NismoKnights ![]() Last edited by Nismoknightska-t; 06-19-2007 at 09:24 PM.. |
#28 |
I had one of these but it sucks. The pressur of the turbo bent the flapper out of shape and now it does not close correctly. I would rather go with a full exhaust and keep that back pressure.
#29 | |
![]() Join Date: Nov 2007
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << |
#30 |
Well if you put it closer to the turbo its gonna happen. If you do like the fellow above you will be alright..
