Old 06-26-2007, 01:28 PM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
SR warmup problems
does anyone ever have problems with their SR when starting their car up.
mine bogs when it starts up cold then after it warms up to 68-75 degrees it runs ok. its pretty warm over here like 80-90 degrees outside and my sr bogs when its cold when starting up around 30-55 degrees.
started doing that when i took my FMIC out to install a push electric fan in the front of the radiator. FMIC was properly installed back on and tightened up so there are no boost leaks.
also running a z32 maf. <------ could it be the problem. never happen when i install the z32 maf. its caliberated with the Power FC to work properly.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
