Old 08-27-2002, 02:31 AM   #1
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
I have a manual controler that has served its purpose for about 2 months now...i have it set for 14psi and under WOT i go to 14psi and no more...in the past few days my boost will spike to 16psi for a split second then go back to 14psi...what culd be causing this......it has just started in the past few days...
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 08-27-2002, 06:00 AM   #2
babylon02
babylon02 is an unknown quantity at this point
I know I don't have a lot of posts, but since when does that mean you really know anything? &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
Double check all your vacuum lines and make sure the condition of them is all good and that none of them are kinked, especially the one your boost controller is off of. &nbsp;Is your boost controller and boost guage running off of the same vacuum line? &nbsp;If so, you might want to isolate them and that might fix the problem too. &nbsp;I am guessing that you haven't made any other mods to your car recently. &nbsp;Because that could do it too.
Hope you find the problem.
babylon02 is offline   Reply With Quote
Old 08-27-2002, 08:03 AM   #3
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (cIvIcKILLA240style @ Aug. 27 2002,03:31)</td></tr><tr><td id="QUOTE">I have a manual controler that has served its purpose for about 2 months now...i have it set for 14psi and under WOT i go to 14psi and no more...in the past few days my boost will spike to 16psi for a split second then go back to 14psi...what culd be causing this......it has just started in the past few days...</td></tr></table><span id='postcolor'>
Did the temperature recently change? &nbsp;MBC's are notorious for "adjusting" boost level due to temperature fluctuations. &nbsp;Maybe a cold front moved through. &nbsp;Maybe it's done this randomly on other occasions, too, and you just noticed it this time.
Otherwise, yeah, check vacuum lines.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-27-2002, 01:32 PM   #4
GamblerZ
GamblerZ's Avatar
GamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enough
Send a message via ICQ to GamblerZ Send a message via AIM to GamblerZ Send a message via MSN to GamblerZ Send a message via Yahoo to GamblerZ
Changes in intake or exhuast will affect your boost pressure. &nbsp;Meanwhile, here is a good reference link:
<a href="http://www.racetep.com/turbo.html" target='_blank'>http://www.racetep.com/turbo.html</a>
Visit WTI - WestTexasImports.net
GamblerZ is offline   Reply With Quote
Old 08-27-2002, 06:13 PM   #5
RedSuns
RedSuns's Avatar
well i did start to notice it after i put on my N1 dual.....thanks guys....
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
Old 08-29-2002, 07:58 AM   #6
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
I would say that it is your exhaust. If you were using the stock exhaust the turbo should be spinning up quite a bit faster now. MBC's are kind of like a blunt instriment, there is no way to get them perfect. If you are really concerned consider lowering the boost or gettign an electronic boost controler.
Lurker Supreme!
www.midatlantic240sx.com
  • 91 Coupe
  • 97 KA24DE+T SOLD
uuninja is offline   Reply With Quote
