Old 08-27-2002, 09:21 AM   #1
maddindian
maddindian is an unknown quantity at this point
Send a message via ICQ to maddindian
How many quarts of tranny oil is needed in an S14....I'm planning on putting synthetic oil in.
-> '99 Maxima GLE <fully loaded>
-> '95 240SX LE 5-spd <fully loaded>
maddindian is offline   Reply With Quote
Old 08-27-2002, 11:02 AM   #2
tnord
tnord's Avatar
tnord is an unknown quantity at this point
4qt iirc
tnord is offline   Reply With Quote
Old 08-27-2002, 11:10 AM   #3
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (tnord @ Aug. 27 2002,12:02)</td></tr><tr><td id="QUOTE">4qt iirc</td></tr></table><span id='postcolor'>
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
Nope. &nbsp;Sorry Travis. &nbsp;No cigar for you.
5 1/8 pints. &nbsp;Buy three quarts (6 pints) and use a little more than 2 and a half of them. &nbsp;I suppose you could save the rest...but why?
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-27-2002, 06:54 PM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (uiuc240 @ Aug. 27 2002,1:10)</td></tr><tr><td id="QUOTE">5 1/8 pints.</td></tr></table><span id='postcolor'>
or 2.4 liters.. &nbsp;since that is the way redline, and I believe amsoil is sold.
sykikchimp is offline   Reply With Quote
Old 08-27-2002, 09:03 PM   #5
tnord
tnord's Avatar
actually, the specs for the tranny oil went up 1qrt.......so a little less than 4 is actually what it should be.
Old 08-28-2002, 08:04 AM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (tnord @ Aug. 27 2002,11:03)</td></tr><tr><td id="QUOTE">actually, the specs for the tranny oil went up 1qrt.......so a little less than 4 is actually what it should be.</td></tr></table><span id='postcolor'>
so you mean on the S14 it requires about 3.5 quarts? &nbsp;
On my s13 it takes exactly 2.4 (just barely drips out the fill hole)
Old 08-28-2002, 08:30 AM   #7
tnord
tnord's Avatar
no, i don't mean on the S14 (considering that all transmissions are the same iirc) and you have to plug the fill hole and dump it in up by the shifter to get the 3.5qts or whatever it takes.
this is just what a tech told me.
Old 08-28-2002, 08:34 AM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
Damnit, now I'm worried about my Tranny
Old 08-28-2002, 11:18 AM   #9
tnord
tnord's Avatar
think this change is nissan's way of recognizing the 3rd gear issue?
Old 08-28-2002, 12:25 PM   #10
uiuc240
uiuc240's Avatar
Really? &nbsp;So when did this happen and where was it written down? &nbsp;Not knocking your tech, but I don't trust them at ALL. &nbsp;Until I see it in a TSB from Nissan, I'm going with the 2.4 liters (5 1/8 pints) listed on the back of the FSM.
Eric
2002 Mazda Protege5
Old 08-28-2002, 01:01 PM   #11
anthony240
anthony240's Avatar
anthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really nice
Send a message via AIM to anthony240
I believe you can fill up the tranny with as much fluid as possible, through the shifter. but not too much, don't want fluid all over the &nbsp;place. so I think 3.5qts should barely fill up the shifter hole. I put in 3qts and I could see the fluid level from the shifter hole. I think the shifter hole is the best place to put tranny fluid in.
18+ to come//21+ to swallow
anthony240 is offline   Reply With Quote
Old 08-28-2002, 02:28 PM   #12
tnord
tnord's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (uiuc240 @ Aug. 28 2002,1:25)</td></tr><tr><td id="QUOTE"><img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
Really? So when did this happen and where was it written down? Not knocking your tech, but I don't trust them at ALL. Until I see it in a TSB from Nissan, I'm going with the 2.4 liters (5 1/8 pints) listed on the back of the FSM.
Eric</td></tr></table><span id='postcolor'>
i know, i agree.........note that i don't take my car there anymore. i was skeptical at first as well......but he swore by it, and i got the service manager to witness his statement, so if something fucks up because of it..........they're payin.
Old 08-28-2002, 02:47 PM   #13
uiuc240
uiuc240's Avatar
Good call with that guarantee. &nbsp;I'm shifting just fine with ~2.6 quarts right now. &nbsp;I'm going to stick with that until my synchros tell me otherwise.
Side note:
The leak I had coming from my OBX shifter (missing pieces) had caused me to lose a whole quart over 5 months. &nbsp;It didn't start out that bad, but it got REALLY bad the last month. &nbsp;I know how much leaked out because I added a quart month from the end, and when I poured the old stuff back into the bottles, it only totaled 2.5 quarts. &nbsp;Yikes! &nbsp;Good thing I added some! &nbsp;You should have seen the underside of my car. &nbsp;Spray from the fluid was just everywhere....still is <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> &nbsp;Should probably clean that off.
Eric
2002 Mazda Protege5
Old 08-29-2002, 09:08 AM   #14
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Well I used the fill hole method of adding trans fluid to my car and filled it right till it started coming out. &nbsp;Then my friend told me I should have stopped just below that line and not to worry, I'll just have a little coming out of the purge vent at the top for a week or so. &nbsp;Sure enough I had a blue puddle under my trans for the first week which stopped growing after that. &nbsp;Car shifts fine and no complaints. &nbsp;I'm guessing with an extra quart, my driveway would have been much wetter than it was but i'd still be running the same amount of fluid after a week.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 08-29-2002, 11:07 AM   #15
tnord
tnord's Avatar
that's interesting, i had no leaking problems at all. maybe the fucker didn't even put the extra quart in and sniped the extra qrt of mobil 1 for himself.......pig fucker........
Old 08-29-2002, 01:00 PM   #16
240 2NR
240 2NR's Avatar
I guess some time i'll check to make sure the level is still good, but it all happened just as predicted so I never worried about it.
Steve
