Old 08-18-2007, 07:22 PM   #1
lonelydrifter
lonelydrifter is making a name for him/her selflonelydrifter is making a name for him/her self
Running GT2871R
Alright I have been searching all day and have really only found setups for maxing out this turbo. What I would like to know is could I get this turbo and run it on stock injectors and maf between 8-10psi without running into problems? I am looking to buy a new turbo because my T25 is gonna take a shit and I would like to just put the money toward a good one and not have to spend money twice. I am not looking for huge power or anything right now just for a good working engine as I have just built an SR and at this point just want it to run reliably.
lonelydrifter is offline   Reply With Quote
Old 08-18-2007, 09:36 PM   #2
scarecrow27
scarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymore
if ur gonna run low boost with stock injectors i see no problem just dont turn it up until u get 550ccs and a new maf
10psi is 10psi whether its comming outta a t25 or a gt35
scarecrow27 is offline   Reply With Quote
Old 08-18-2007, 09:53 PM   #3
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Uh, no it isn't. I can see why your rep is so bad.
Flybert is offline   Reply With Quote
Old 08-18-2007, 11:02 PM   #4
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
wow..now ive seen it all. a gt35r will flow a shit ton more air than a t25 would at 10psi. go read a few books and come back when your a little more educated son.
ch1873857 is offline   Reply With Quote
Old 08-19-2007, 02:38 AM   #5
cotbu
cotbu's Avatar
He is right, but he is wrong and wrong as hell!
$=10psi -T25
@=10psi-GT35
$$$$$$$$$ T25 flow a minute
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ GT35 flow a minute
So in about 5 minutes your done.
I'm an idiot say it with me.
Old 08-19-2007, 10:18 AM   #6
lonelydrifter
Well I knew that and thats why im asking. Is the extra air flow gonna require maf and injectors to run safely at about 8psi?
Old 08-19-2007, 10:30 AM   #7
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
i was runnin around with one for a few days on 7 lbs and i didnt have a
problem with detonating, just make sure you run the proper oil lines, or the
right sized fittings those garrett ball berings dont like alot of oil pressure
sr20boostn20 is offline   Reply With Quote
Old 08-19-2007, 10:34 AM   #8
lonelydrifter
Hmm...Alright.
Old 08-19-2007, 07:09 PM   #9
lonelydrifter
Anyone else got some input?
Old 08-20-2007, 06:37 PM   #10
Flybert
If you can't afford to do all the supporting modifications, just get another t25 for the time being. It'll cost you like $150 and a few hours of your time and you can always sell it when you are done with it. I personally wouldn't run the gt2871 without engine management.
Old 08-20-2007, 06:42 PM   #11
johngriff
johngriff's Avatar
What flybert said.
Everything really needs to be all together and working well, for things to go well. Engine management and deachwerks injectors are about the price of another swap, which you'll be doing, if you dont, then you'll be stuck at stock again.
Unless you DONT want to spend the money, in which case, get out of the game, and get a camry.
[email protected]
Old 08-20-2007, 06:52 PM   #12
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
10PSI out of a T25 and 10PSI out of a gt28 is the same air pressure, yes. The difference lies in the amount of air, that is at 10PSI, that each turbo can flow. That difference is why, other mods notwithstanding, a gt28 at 10PSI would produce more horsepower then a T25 at 10PSI.
I'm with Flybert and johngriff... just wait till you got the money for the needed supporting mods. T25 is cheap and quick to replace, and it's better to buy a T25, and wait and still be able to drive, then buy a gt28, slap it on, and grenade your engine the first time you hit boost.
mRclARK1 is offline   Reply With Quote
Old 08-20-2007, 07:25 PM   #13
smelly240
smelly240's Avatar
+1 ^^^
im with u guys... dont get in over ur head it will cost u more in the long run.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 08-20-2007, 10:54 PM   #14
TibDrifter
TibDrifter is an unknown quantity at this point
just use the t25 till it craps out, take good care of it and it will last you a while. waite till you get the supporting mods, fmic, injectors and management. that get the 2871r
TibDrifter is offline   Reply With Quote
Old 08-21-2007, 07:45 AM   #15
Sileighty_85
Sileighty_85's Avatar
Get a rebuild off of EBay they are only 60 bucks Ive rebuilt 4 of them so far with no problems and very easy to do
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-21-2007, 08:15 AM   #16
hayaimoto
hayaimoto's Avatar
hayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud of
Keep the boost low, the 2871 would already make a little more power at the same boost as your t25 did. If you want to play it cautiously, buy some injectors and fuel management before you turn it up!
T25's are infamous for taking a dump...Its just cause there so dang old.
Good luck!
hayaimoto is offline   Reply With Quote
