Old 01-17-2002, 01:23 PM   #1
AZN GTR
AZN GTR is an unknown quantity at this point
I got my remote starter like a month ago, first, it works, then, when it got colder, it cranks but doesn't start sometimes.  So I thought it was the battery, so I got a new one, and it got even worse, (but the weather has been about the same)  then I thought it was spark plugs, but I realized that when I use the key to start it, there is never a problem.  Right now, the remote starter only works when the car is warm, which is completely pointless.  I have work tomorrow, so I will talk to the mechanic who installed it, but he's probably gonna be a dick about it.  I tried reseting the starter, and it doesn't work.  It's just really weird.  Anybody knows why?
AZN GTR is offline   Reply With Quote
Old 01-17-2002, 03:51 PM   #2
Silviaboy
Silviaboy is an unknown quantity at this point
Do you tap the gas when you start you car with the key? If so the remote starter can not do this to my knowledge. This is most likely you problem and the problem with most remote starters. The engine needs a bit more air and gas on cold starts. I hope this helps and keep me posted.
Silviaboy is offline   Reply With Quote
Old 01-17-2002, 05:12 PM   #3
AZN GTR
No, I don't step on the gas at all when I start it with keys.
Old 01-17-2002, 08:07 PM   #4
gh6o6
gh6o6 is an unknown quantity at this point
mabe your remote starter unit isent getting enough power to the starter - ofcourse this is a guess and im talking from my ass
gh6o6 is offline   Reply With Quote
Old 01-18-2002, 12:29 AM   #5
nguyen
nguyen is an unknown quantity at this point
if it is a 240 then the 2nd starter wire not getting power when the starter being crank. the best way to test to see if this is the problem, press the start button then as soon as the starter start cranking you turn the key on and start with the key at the same time, if the car start then that is the problem. then just open the dash and hook up the black yellow and the black green together this should work.
nguyen is offline   Reply With Quote
