Old 09-21-2007, 05:32 PM   #1
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
Safe minimum clearance between coilover/tire...I'm at 5mm
I'm fitting RPF1's 17x9 +22 with 255/40/17 NT01s to the front of my S14 and I have exactly 5mm between the upper coilover collar and widest part of the tire. I think it should be fine but I'm wondering what others think...
sean350z is offline   Reply With Quote
Old 09-21-2007, 06:06 PM   #2
Nachtmensch
Nachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond repute
go drive around, if it rubs, then add a spacer.
Nachtmensch is offline   Reply With Quote
Old 09-21-2007, 06:07 PM   #3
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
cornering forces will distort the tires and deflect the bushings to a point where the tire may rub. Put some tire chalk on the coilover and take a ride. If the mark had rubbed then you could put a small spacer on the hub. good luck!
RedtopTech is offline   Reply With Quote
