Old 09-27-2007, 08:36 PM   #1
sip
sip is on a distinguished road
Changing coilover Springs
My Silkroads are too bouncy for my roads. It's not that they are too stiff on a sudden bump, it handles those quite well. I can hit a pothole and be ok. It just seems to bounce up and down on roads that have dips it them.
I was looking at changing my spring rates. Has anyone done this. What were your impressions? Will this help my problem or is the dampening the aspect i need to address?
Thanks.
sip is offline   Reply With Quote
Old 09-27-2007, 08:59 PM   #2
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
Your still uncomfortable even at the softest setting?
So what are you are going to go with a softer spring rate?
A general rule of thumb is to stay + or - 2k from the original spring rate.
A softer spring rate will help with the "comfort"
BUT
My advice: Man the fuck up, or sell the silkroads and get a softy spring/shock pussy setup.
Silkroads are a pretty damn comfortable coilover compared to most.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 09-27-2007, 09:49 PM   #3
gotta240
How old/blown are your struts
Old 09-27-2007, 09:50 PM   #4
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Springs generally won't make the car bouncy unless they are significantly too stiff for the shock valving. It sounds to me like your coilovers need to be rebuilt. How long have you had them and did u buy them new or used?
Old 09-28-2007, 05:19 AM   #5
sip
I thought they would be more comfortable then they turned out to be.
They are on the softest setting. It is not good for performance when I can't control the accelerator (gas pedal) due to me bouncing around in the car. The roads are pretty bad here.
Yeah i was wondering about 6/5 rate combo.
I bought them new and they have less than 2000 miles on them
I'm thinking about ditching them for some Tein Flexes, I heard they are the best "comfort -wise". It will cost me $500 to changes springs on the silks.
Old 09-28-2007, 05:28 AM   #6
yokotas13
yokotas13's Avatar
ill gibe you 600 for hte silkroads
yokotas13 is offline   Reply With Quote
Old 09-28-2007, 06:13 AM   #7
sip
I'm sure you will Grant.
I don't know if I want to sell them yet, but I'd want $800+.
Can you lend some help with my question, ...you know, given your breadth of knowledge.
Old 09-28-2007, 06:20 AM   #8
yokotas13
yokotas13's Avatar
yeah, talk to Logan from aspec
ask him about some Sprint springs
should onl be like 250 for 4 springs
Old 09-28-2007, 06:59 AM   #9
sip
$95 PER Spring on aspec site.
$99 per spring from Silkroad.
Old 09-28-2007, 07:38 AM   #10
gotta240
sprints SHOULD be cheaper than that. You don't have to stick with the same brand as your coilovers.
Old 09-28-2007, 10:49 AM   #11
aznpoopy
aznpoopy's Avatar
full soft to 4 clicks on silkroads are pretty much useless unless you live in an area with very nice roads
turn up the damping
aznpoopy is offline   Reply With Quote
Old 09-28-2007, 01:47 PM   #12
sip
turn up the damping
That seems counter intuitive. Why would going firmer be better for crappy roads?
Old 09-28-2007, 02:08 PM   #13
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
fuck them cheap china made springs. Buy some real springs. SWIFT or go home.
Jung918 is offline   Reply With Quote
Old 09-28-2007, 02:31 PM   #14
aznpoopy
aznpoopy's Avatar
spring shock system = oscillation and damping system, like a pendulum
if you shock is not able to damp the spring oscillation, (i.e. damper stiffness set too low) then the spring oscillates i.e. goes up and down multiple times before coming to rest i.e. bounces.
if the shock is set properly for the spring, the suspension will absorb the bump and resettle to normal state within one oscillation cycle in the shortest time. ie = no bounce. iirc this is called critical damping. thank you linear algebra / math models of real world systems. college teaches you something.
if the shock is set too stiff, then it does not allow the spring to absorb the bump and you get a stiff ass ride. this also makes the system take longer to settle to resting state.
this also plays into how alot of japanese coilover shocks are crappy, in that the adjustment never gives you the right combo of compression & rebound for it to be comfy. its either too bouncy or too stiff.
Old 09-28-2007, 02:40 PM   #15
sip
So what you're saying is that changing springs won't help me. \
I have played with the dampening, the smoothest ride was on full soft. I'll go try again though.
Old 09-28-2007, 02:44 PM   #16
aznpoopy
aznpoopy's Avatar
i definitely did not say that
lol
changing to softer springs probably will help if you're deadset on riding around on them at full soft.
Old 09-28-2007, 06:06 PM   #17
sip
I played around withthe dampening. It seems to make very little difference. After 7 different setting pairs, the best setting I found was 6 front and 5 rear (from soft). The ride is slightly less bouncy, and slightly more jarring.
I'm perplexed. Maybe I'll try the different spring rate, but fromt he sounds of your (azn) explanation, the strut might be OVER dampened.
Old 09-29-2007, 04:37 PM   #18
aznpoopy
aznpoopy's Avatar
i have silkroads too. that's generally where i keep it as well. a little harsh but no bounce.
imo its not overdamping, rather
not the right mix of rebound/compression
the right ratio simply isn't build into the adjustment
Old 09-29-2007, 05:27 PM   #19
sip
Humm, that's cool. We both found the same setting, completely independant of one another. That is comforting that you found 6/5 too be the best as well, because after 5 or 6 run tests, I was beginning not to be able to tell the difference.
So Nothing I do will make much of a difference in terms of ride quality. That sucks. I bought Silkroads because everyone I talked to said they were perfectly dampened. Guess not.
Have you ever owned any other coilovers?
How do they compare?
Old 09-29-2007, 09:15 PM   #20
yokotas13
yokotas13's Avatar
spring and swift are both fantastic springs
Old 09-30-2007, 10:24 AM   #21
!Zar!
!Zar!'s Avatar
What's you're preload set at?
Old 10-01-2007, 03:15 PM   #22
aznpoopy
aznpoopy's Avatar
i have not owned any others but i have sat in a few
k-sports - suck. 6 months old. felt like they were blown. and maybe they were.
tein flex (in an evo) - impressed
megans - lol. car was fucked up though.
nismo r-tune - wow. too bad they are $$$ and not dual height adjustable.
Old 10-12-2007, 06:36 AM   #23
sip
Just touching the perch.
AZN POOPY:
So the Tein Flex's where more comfortable than your Silkroads. Too bad it wasn't on an S13 so it would give a good comparison.
Old 10-12-2007, 07:57 AM   #24
Dunkee
Dunkee's Avatar
Dunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of light
I doubt Flex are more comfy then the silkroads..then again I've never driven w/ the silkroads. I have Flex and thought they were bouncy for these roads..I changed the spring rate to 4 in the back (S14) and its a LOT better now. Goes over bumps smoother w/out have to go super soft on the damper but I also don't have the car slammed so that helps too.
96 SE http://www.cardomain.com/ride/255381
Dunkee is offline   Reply With Quote
Old 10-12-2007, 10:03 AM   #25
sip
Actually that does help. My car isn't slammed either ( tried it 1 day and scraped on EVERYTHING) so now i keep about 1 inch of wheels gap.
So you just changed the back to 4K, and kept the front a 7K?
Old 10-12-2007, 10:49 AM   #26
aznpoopy
aznpoopy's Avatar
yes and no on the flex
it was on an EVO, not a 240sx. so take it as you will.
the comfiest coilovers i've ever experienced for a 240sx are by FAR nismo R-tunes. too bad they are expensive and only single height adjustable.
Old 10-13-2007, 03:24 PM   #27
sip
Dunkee:
Anyone: The springs on the front are the same as the springs on the rear, right?
That would make it easier on me because I could put the 6K from the rear on the front and buy some 4.5K ones for the rear.
Old 10-13-2007, 03:37 PM   #28
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
maybe try some tein basics this time?
JRas is offline   Reply With Quote
Old 10-13-2007, 03:40 PM   #29
sip
overpriced, no pillowball mounts and crappy hight adjustment (if you can even call that height adj.) i'd have to be
Old 10-13-2007, 04:59 PM   #30
Dunkee
Dunkee's Avatar
Flex is 6 in front so 6/4. Comes originally 6/5 for S14. Btw most comfy coilovers I've been in are the Zeal functions..those things are smooth perfect balance.
