Old 10-09-2007, 09:41 PM   #1
stillen
stillen is an unknown quantity at this point
S14 Sr20det Hks Step 2 Camshaft & Vtc
Hi guys, I posted before about VTC in an S14 SR20DET making a rattle noise in my engine between 1000-2000rpms and when I let go off the gas, didn't get any solutions. Now I have decided to get rid of the VTC. From the manual it said that the VTC advances(or retards, I dont know which) the cam by 20 degrees and it is active between 1050-5700rpm. Now I already have HKS step 2 264 for intake and 272 for exhaust.
My questions: Please note I want to eliminate VTC
1. Will I have the same torque curve with the VTC enabled and a stock cam when compared to VTC disabled and 264 step 2 intake cam?
2.Should I just remove the intake camsprocket and put an adjustable cam gear with the HKS cam shaft? and how much should I advance or retard the cam with this to get the same or better torque curve as the VTC?
3. If I get adjustable cam gears, will it be ok to use the S14 HKS step 2 264 cam or do I need to buy the S13 HKS intake camshaft?
Please note again I want to eliminate the VTC because of the noise and no fix and that I am using stock ECU, turbo and injectors. Thanks all for looking and for all your input. Please no arguing and no calling people names.
stillen is offline   Reply With Quote
Old 10-09-2007, 10:28 PM   #2
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
Why are you using a stock ECU with high duration cams?
VTC doesn't do anything anyways. Get rid of it and run 0 degrees on both sides.
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 10-09-2007, 10:38 PM   #3
stillen
I am still running stock cams. Are you saying I should run the hks step 2 cams with 0 degrees? will I have the same power as having the VTC with stock cams? And trust me disabling the VTC with stock cams makes a very noticeble difference.
