Old 10-28-2007, 08:51 AM   #1
SSMini
SSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the rough
Question regarding HKS Step 1 264's & Step 2 264's camshafts.
Did a search and after reading all that I could find I did not find the info I'm looking for. Can somebody explain the difference between the HKS Step 1 & Step 2 264's?? Performance wise. Im shopping around for cams and need some assestance from you perfromance guru's. Which cam would be better for my set up? I'll be running 550 injectors, T28 turbo, and ALL your bolt on performance parts. I've picked up some Greddy valve springs, Apexi head gasket, ARP head studs, Trust rocker arm stoppers and just looking for a set of cams to complete the head. Should I go with the Step 1 264's or the Stage 2 264's. I think I can get a good deal on the step 2 264's from a local shop. If you guys think I can run the HKS Step 2 264's, I'll just pick them up and be done with it.
Thanks.....
SSMini is offline   Reply With Quote
