Old 10-28-2007, 11:00 PM   #1
ibestevo
ibestevo is an unknown quantity at this point
Car Wont Start
Hey guys; So I swapped in a working DOHC engine into my 240. My car is a '89 Fastback base model. Anyway, while I was dropping the DOHC in the car I took off the a/c compressor and swapped in the DOHC ps hardlines. After the engine was in I connected all plugs, connected driveshaft, put in all fluids, and soldered all wires connecting to the ECU. Tried starting the engine and it wouldn't turn over. So I went on nicoclub and went looking for torubleshooting threads. I found one and followed all the procedures. I checked all of the fuel injectors to see if fuel was squirting; works. I checked spark with all wires and all plugs; works. I checked timing as well and that also is not the problem. Those were the three stated procedures to get troubleshooting done. All are not my problem. I have also searched Zilvia's threads for troubleshooting but I had trouble finding any different problems to look for. So if anybody has any ideas I could possibly check to get it running, it will be greatly appreciated. Thanks.
-Steven
-sorry for double post x_x
Last edited by ibestevo; 10-28-2007 at 11:03 PM.. Reason: sorry for double post x_x
ibestevo is offline   Reply With Quote
Old 10-28-2007, 11:05 PM   #2
silversr
silversr's Avatar
silversr is making a name for him/her selfsilversr is making a name for him/her selfsilversr is making a name for him/her self
Is there power to the starter?
silversr is offline   Reply With Quote
Old 10-28-2007, 11:09 PM   #3
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
check the main relay..
Slammed Assassin is offline   Reply With Quote
Old 10-28-2007, 11:11 PM   #4
ibestevo
Where is the main relay located? And how would I check that?
Old 10-29-2007, 01:28 PM   #5
ibestevo
Anybody help ?
~bump
Old 10-29-2007, 01:56 PM   #6
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
maby you flooded it
sr20boostn20 is offline   Reply With Quote
Old 11-06-2007, 03:16 PM   #7
unit_121
unit_121 has made poor choicesunit_121 has made poor choicesunit_121 has made poor choicesunit_121 has made poor choicesunit_121 has made poor choicesunit_121 has made poor choices
check to see if you gave a ground to your battery terminals, maybe your not getting a reading.
unit_121 is offline   Reply With Quote
Old 11-06-2007, 09:08 PM   #8
BoostinGST
BoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant future
check for vacuum leaks... make sure your o2 is plugged in... take out the plugs and make sure they are clean...
if the starter isnt working check all your starter wiring for shorts, try bypassing the relay/jumping the starter, check your ignition switch, etc.
www.DecalsStore.com custom decals... buy a premie account and save money from me
BoostinGST is offline   Reply With Quote
Old 11-08-2007, 08:16 AM   #9
used240sxparts
Guest
Posts: n/a
are you sure timing is fine? alot of people put the distributor in backwards... also make sure you are first priming the system so you are getting fuel..turn key to acessorie turn off....repeat like 3 or 4times
Old 10-28-2007, 11:08 PM   #10
ibestevo
Yeah all three. Cranks like a beast just won't turn over.
Old 10-29-2007, 01:36 PM   #11
jesuchristo
jesuchristo is making his/her stupidity well-knownjesuchristo is making his/her stupidity well-knownjesuchristo is making his/her stupidity well-knownjesuchristo is making his/her stupidity well-known
I think your definition of "turn over" is different than most.
Let me get this straight. The engine will crank (turn over) but it wont start?
If it wont even crank, its a problem with your starting system. Check your starter, relays, fuses etc. relating to that.
Get a chilton manual or a FSM
jesuchristo is offline   Reply With Quote
